Connecting esp32 to wireless headset
i have deadline 2 days, and i know nothing about programming esp32. I need code to connect headset to esp32 and play something through it. Iused this code, but arduino ide is senting error GitHub - schreibfaul1/ESP32_A2DP_Source: Arduino version. please help me
I moved your topic to an appropriate forum category @kolenka2007.
In the future, please take some time to pick the forum category that best suits the subject of your topic. There is an "About the _____ category" topic at the top of each category that explains its purpose.
This is an important part of responsible forum usage, as explained in the "How to get the best out of this forum" guide. The guide contains a lot of other useful information. Please read it.
Thanks in advance for your cooperation.
Hi @kolenka2007.
Please post the full and exact text of the error message:
  1. Copy the error message text in Arduino IDE.
  2. Open a forum reply here by clicking the "Reply" button.
  3. Click the <CODE/> icon on the post composer toolbar.
    This will add the forum's code block markup (```) to your reply to make sure the error messages are correctly formatted.
    Code block icon on toolbar
  4. Press the Ctrl+V keyboard shortcut (Command+V for macOS users).
    This will paste the compilation output into the code block.
  5. Move the cursor outside of the code block markup before you add any additional text to your reply.
  6. Click the "Reply" button to post the output.
In case the output is longer than the forum software will allow to be added to a post, you can instead save it to a .txt file and then attach that file to a reply here:
  1. Open any text editor program.
  2. Paste the copied output into the text editor.
  3. Save the file in .txt format.
  4. Open a forum reply here by clicking the "Reply" button.
  5. Click the "Upload" icon (image) on the post composer toolbar:
    Upload icon on toolbar
    The "Open" dialog will open.
  6. Select the .txt file you saved from the "Open" dialog.
  7. Click the "Open" button.
    The dialog will close.
  8. Click the "Reply" button to publish the post.
Alternatively, instead of using the "Upload" icon on the post composer toolbar as described in steps (5) - (7) above, you can simply drag and drop the .txt file onto the post composer field to attach it.
c:/users/rckblck/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/esp-2021r2-patch5-8.4.0/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\rckblck\AppData\Local\Temp\arduino\cores\f2d74460c627413f1cb24e3b838fe9b6\core.a(main.cpp.o):(.literal._Z8loopTaskPv+0x8): undefined reference to `setup()'
c:/users/rckblck/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/esp-2021r2-patch5-8.4.0/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\rckblck\AppData\Local\Temp\arduino\cores\f2d74460c627413f1cb24e3b838fe9b6\core.a(main.cpp.o):(.literal._Z8loopTaskPv+0xc): undefined reference to `loop()'
c:/users/rckblck/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/esp-2021r2-patch5-8.4.0/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\rckblck\AppData\Local\Temp\arduino\cores\f2d74460c627413f1cb24e3b838fe9b6\core.a(main.cpp.o): in function `loopTask(void*)':
C:\Users\rckblck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.11\cores\esp32/main.cpp:42: undefined reference to `setup()'
c:/users/rckblck/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/esp-2021r2-patch5-8.4.0/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\rckblck\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.11\cores\esp32/main.cpp:48: undefined reference to `loop()'
collect2.exe: error: ld returned 1 exit status
exit status 1
Compilation error: exit status 1
Every Arduino sketch must contain a function named setup and one named loop. This error indicates those functions are missing from your sketch.
Even though they aren't true Arduino sketches, the example programs in that repository do have setup and loop functions so I would not expect the error if you are using them.
Please post your full sketch.
I'll provide instructions you can follow to do that:
  1. Select Tools > Auto Format from the Arduino IDE menus.
    This is done to make the code easier for us to read.
  2. Select Edit > Copy for Forum (Markdown) from the Arduino IDE menus.
  3. In a forum reply here, click on the post composer field.
  4. Press the Ctrl+V keyboard shortcut.
    This will paste the sketch to the post composer.
  6. Repeat the above process if your sketch has multiple tabs.
  7. Click the "Reply" button to post your reply.
When your code requires a library that's not included with the Arduino IDE please post a link to where you downloaded that library from, or if you installed it using Library Manager (Sketch > Include Library > Manage Libraries... in Arduino IDE) then say so and state the full name of the library.
I forgot to say that i put file A2DP_source.h (from the github link) with the same path as another file ended by ".h" . I did this because when i installed file from github in arduino ide it gave error.
 * a2dp_source.c
 *  Created on: 27.08.2020
 *      Author: wolle
 *  updated on: 28.12.2021
 *  use Arduino Version >= 2.0.4
#include <Arduino.h>
#include "a2dp_source.h"
extern String BT_DEVICE_NAME;
static esp_bd_addr_t s_peer_bda = { 0 };
static char s_peer_bdname[ESP_BT_GAP_MAX_BDNAME_LEN + 1];
static int m_a2d_state = APP_AV_STATE_IDLE;
static int m_media_state = APP_AV_MEDIA_STATE_IDLE;
static String s_BT_sink_name = "";
static esp_bt_pin_code_t s_pin_code = "";
static int s_pin_code_length = 0;
static TimerHandle_t s_tmr;
static bool m_bt_enabled = false;  // blue tooth app
static bool m_hb_enabled = false;  // heart beat
static bt_app_msg_t m_msg;
bool bt_app_work_dispatch(uint16_t event, void *p_params, int param_len) {
  memset(&m_msg, 0, sizeof(bt_app_msg_t));
  m_msg.sig = BT_APP_SIG_WORK_DISPATCH;
  m_msg.event = event;
  m_msg.cb = bt_app_av_sm_hdlr;
  if (p_params && param_len > 0) {
    if ((m_msg.param = malloc(param_len)) != NULL) {
      memcpy(m_msg.param, p_params, param_len);
  return false;
void bt_loop() {
  static uint32_t timer = 0;
  if (m_bt_enabled) {
    if (m_msg.sig > 0) {
      switch (m_msg.sig) {
        case BT_APP_SIG_WORK_DISPATCH:
          vTaskDelay(50);  // is absolutely necessary
          bt_app_av_sm_hdlr(m_msg.event, m_msg.param);
        default:
          log_e("unhandled sig: %d", m_msg.sig);
      if (m_msg.param) { free(m_msg.param); }
      m_msg.sig = 0;
    } else if (m_hb_enabled) {
      if (timer < millis()) {
        timer = millis() + 1000;
        bt_app_work_dispatch(BT_APP_HEART_BEAT_EVT, NULL, 0);
void a2dp_source_stop(void) {
char *bda2str(esp_bd_addr_t bda, char *str, size_t size) {
  if (bda == NULL || str == NULL || size < 18) {
    return NULL;
  uint8_t *p = bda;
  sprintf(str, "%02x:%02x:%02x:%02x:%02x:%02x",
          p[0], p[1], p[2], p[3], p[4], p[5]);
  return str;
bool get_name_from_eir(uint8_t *eir, uint8_t *bdname, uint8_t *bdname_len) {  // extended inquiry response
  uint8_t *rmt_bdname = NULL;
  uint8_t rmt_bdname_len = 0;
  if (!eir) {
    return false;
  rmt_bdname = esp_bt_gap_resolve_eir_data(eir, ESP_BT_EIR_TYPE_CMPL_LOCAL_NAME, &rmt_bdname_len);
  if (!rmt_bdname) {
    rmt_bdname = esp_bt_gap_resolve_eir_data(eir, ESP_BT_EIR_TYPE_SHORT_LOCAL_NAME, &rmt_bdname_len);
  if (rmt_bdname) {
    if (rmt_bdname_len > ESP_BT_GAP_MAX_BDNAME_LEN) {
      rmt_bdname_len = ESP_BT_GAP_MAX_BDNAME_LEN;
    if (bdname) {
      memcpy(bdname, rmt_bdname, rmt_bdname_len);
      bdname[rmt_bdname_len] = '\0';
    if (bdname_len) {
      *bdname_len = rmt_bdname_len;
    return true;
  return false;
void filter_inquiry_scan_result(esp_bt_gap_cb_param_t *param) {
  char bda_str[18];
  uint32_t cod = 0;
  int32_t rssi = -129; /* invalid value */
  uint8_t *eir = NULL;
  esp_bt_gap_dev_prop_t *p;
  char *sd = bda2str(param->disc_res.bda, bda_str, 18);
  for (int i = 0; i < param->disc_res.num_prop; i++) {
    p = param->disc_res.prop + i;
    switch (p->type) {
      case ESP_BT_GAP_DEV_PROP_COD:
        cod = *(uint32_t *)(p->val);
        // NB enumeration is listed in
      case ESP_BT_GAP_DEV_PROP_RSSI:
        rssi = *(int8_t *)(p->val);
      case ESP_BT_GAP_DEV_PROP_EIR:
        eir = (uint8_t *)(p->val);
      case ESP_BT_GAP_DEV_PROP_BDNAME:
      default:
  if (eir) get_name_from_eir(eir, (uint8_t *)s_peer_bdname, NULL);
  else s_peer_bdname[0] = 0;
  char *buf;
  buf = (char *)malloc(strlen(sd) + strlen(s_peer_bdname) + 70);
  if (buf) {
    sprintf(buf, "Scanned device: %s  --Class of Device: 0x%x, --RSSI %d, --%s", sd, cod, rssi, s_peer_bdname);
    if (bt_info) bt_info(buf);
    else log_i("%s", buf);
    if (buf) free(buf);
  /* search for device with MAJOR service class as "rendering" in COD */
  if (!esp_bt_gap_is_valid_cod(cod) || !(esp_bt_gap_get_cod_srvc(cod) & ESP_BT_COD_SRVC_RENDERING)) {
    log_e("cod is not valid");
    return;
  /* search for device named  BT_SINK in its extended inqury response */
  if (eir) {
    if (strcmp((char *)s_peer_bdname, s_BT_sink_name.c_str()) != 0) {
      log_i("s_peer_bdname %s, s_BT_sink_name %s", s_peer_bdname, s_BT_sink_name.c_str());
      return;
    BT_INFO("Found a target device, address %s, name %s", bda_str, s_peer_bdname);
    m_a2d_state = APP_AV_STATE_DISCOVERED;
    memcpy(s_peer_bda, param->disc_res.bda, ESP_BD_ADDR_LEN);
    esp_bt_gap_cancel_discovery();
void bt_app_gap_cb(esp_bt_gap_cb_event_t event, esp_bt_gap_cb_param_t *param) {
  switch (event) {
    case ESP_BT_GAP_DISC_RES_EVT:
        if (m_media_state == APP_AV_MEDIA_STATE_STARTED) break;  // no longer require discovery results
        filter_inquiry_scan_result(param);
    case ESP_BT_GAP_DISC_STATE_CHANGED_EVT:
        if (param->disc_st_chg.state == ESP_BT_GAP_DISCOVERY_STOPPED) {
          if (m_a2d_state == APP_AV_STATE_DISCOVERED) {
            m_a2d_state = APP_AV_STATE_CONNECTING;
            BT_INFO("Device discovery stopped: a2dp connecting to peer: %s", s_peer_bdname);
            esp_a2d_source_connect(s_peer_bda);
            // not discovered, continue to discover
            // log_i("Device discovery failed, continue to discover...");
            esp_bt_gap_start_discovery(ESP_BT_INQ_MODE_GENERAL_INQUIRY, 10, 0);
        } else if (param->disc_st_chg.state == ESP_BT_GAP_DISCOVERY_STARTED) {
          //log_i("Discovery started.");
    case ESP_BT_GAP_RMT_SRVCS_EVT:
    case ESP_BT_GAP_RMT_SRVC_REC_EVT:
    case ESP_BT_GAP_AUTH_CMPL_EVT:
        if (param->auth_cmpl.stat == ESP_BT_STATUS_SUCCESS) {
          log_i("authentication success: %s", param->auth_cmpl.device_name);
          log_e("authentication failed, status:%d", param->auth_cmpl.stat);
    case ESP_BT_GAP_PIN_REQ_EVT:
        log_i("ESP_BT_GAP_PIN_REQ_EVT min_16_digit:%d", param->pin_req.min_16_digit);
        if (param->pin_req.min_16_digit) {
          log_i("Input pin code: 0000 0000 0000 0000");
          esp_bt_pin_code_t pin_code = { 0 };
          esp_bt_gap_pin_reply(param->pin_req.bda, true, 16, pin_code);
          log_i("Input pin code: 1234");
          esp_bt_pin_code_t pin_code;
          pin_code[0] = '1';
          pin_code[1] = '2';
          pin_code[2] = '3';
          pin_code[3] = '4';
          esp_bt_gap_pin_reply(param->pin_req.bda, true, 4, pin_code);
          log_i("Input pin code: %s", s_pin_code);
          esp_bt_gap_pin_reply(param->pin_req.bda, true, s_pin_code_length, s_pin_code);
    case ESP_BT_GAP_CONFIG_EIR_DATA_EVT:
      log_i("ESP_BT_GAP_CONFIG_EIR_DATA_EVT: stat:%d num:%d", param->config_eir_data.stat, param->config_eir_data.eir_type_num);
    case ESP_BT_GAP_MODE_CHG_EVT:
      log_i("ESP_BT_GAP_MODE_CHG_EVT: mode: %d", param->mode_chg.mode);
    default:
        log_e("unhandled event: %d", event);
  return;
void bt_app_a2d_cb(esp_a2d_cb_event_t event, esp_a2d_cb_param_t *param) {
  bt_app_work_dispatch(event, param, sizeof(esp_a2d_cb_param_t));
void bt_app_av_sm_hdlr(uint16_t event, void *param) {
  switch (m_a2d_state) {
    case APP_AV_STATE_DISCOVERING:
      print_status();
    case APP_AV_STATE_DISCOVERED:
      print_status();
    case APP_AV_STATE_UNCONNECTED:
      print_status();
      bt_app_av_state_unconnected(event, param);
    case APP_AV_STATE_CONNECTING:
      print_status();
      bt_app_av_state_connecting(event, param);
    case APP_AV_STATE_CONNECTED:
      print_status();
      bt_app_av_state_connected(event, param);
    case APP_AV_STATE_DISCONNECTING:
      print_status();
      bt_app_av_state_disconnecting(event, param);
    default:
      log_e("invalid state %d", m_a2d_state);
void bt_app_av_state_unconnected(uint16_t event, void *param) {
  switch (event) {
    case ESP_A2D_CONNECTION_STATE_EVT:
    case ESP_A2D_AUDIO_STATE_EVT:
    case ESP_A2D_AUDIO_CFG_EVT:
      log_d("ESP_A2D_AUDIO_CFG_EVT");
    case ESP_A2D_MEDIA_CTRL_ACK_EVT:
    case BT_APP_HEART_BEAT_EVT:
        uint8_t *p = s_peer_bda;
        BT_INFO("Heartbeat Event: a2dp most recent peer connection: %s @ %02x:%02x:%02x:%02x:%02x:%02x",
                s_peer_bdname, p[0], p[1], p[2], p[3], p[4], p[5]);
    default:
      log_e("unhandled evt %d", event);
void bt_app_av_state_connecting(uint16_t event, void *param) {
  esp_a2d_cb_param_t *a2d = NULL;
  switch (event) {
        a2d = (esp_a2d_cb_param_t *)(param);
        if (a2d->conn_stat.state == ESP_A2D_CONNECTION_STATE_CONNECTED) {
          m_a2d_state = APP_AV_STATE_CONNECTED;
          esp_bt_gap_set_scan_mode(ESP_BT_NON_CONNECTABLE, ESP_BT_NON_DISCOVERABLE);
        } else if (a2d->conn_stat.state == ESP_A2D_CONNECTION_STATE_DISCONNECTED) {
          m_a2d_state = APP_AV_STATE_UNCONNECTED;
        } else if (a2d->conn_stat.state == ESP_A2D_CONNECTION_STATE_CONNECTING) {
        print_status();
      log_d("ESP_A2D_AUDIO_STATE_EVT");
      log_d("ESP_A2D_MEDIA_CTRL_ACK_EVT");
      if (a2d)
        if (a2d->conn_stat.state == ESP_A2D_CONNECTION_STATE_CONNECTED) log_i("a2dp connected");
      //        if (++s_connecting_intv >= 2) {
      //            m_a2d_state = APP_AV_STATE_UNCONNECTED;
      //            s_connecting_intv = 0;
    default:
      log_e("unhandled evt %d\n", event);
void bt_app_av_media_proc(uint16_t event, void *param) {
  switch (m_media_state) {
    case APP_AV_MEDIA_STATE_IDLE:
        if (event == BT_APP_HEART_BEAT_EVT) {
          //log_i("a2dp media ready checking ...");
          esp_a2d_media_ctrl(ESP_A2D_MEDIA_CTRL_CHECK_SRC_RDY);
        } else if (event == ESP_A2D_MEDIA_CTRL_ACK_EVT) {
          if (a2d->media_ctrl_stat.cmd == ESP_A2D_MEDIA_CTRL_CHECK_SRC_RDY && a2d->media_ctrl_stat.status == ESP_A2D_MEDIA_CTRL_ACK_SUCCESS) {
            //log_i("a2dp media ready, starting ...");
            esp_a2d_media_ctrl(ESP_A2D_MEDIA_CTRL_START);
            m_media_state = APP_AV_MEDIA_STATE_STARTING;
    case APP_AV_MEDIA_STATE_STARTING:
          if (a2d->media_ctrl_stat.cmd == ESP_A2D_MEDIA_CTRL_START && a2d->media_ctrl_stat.status == ESP_A2D_MEDIA_CTRL_ACK_SUCCESS) {
            log_i("a2dp media start successfully.");
            //s_intv_cnt = 0;
            m_media_state = APP_AV_MEDIA_STATE_STARTED;
            // not started succesfully, transfer to idle state
            log_e("a2dp media start failed.\n");
    case APP_AV_MEDIA_STATE_STARTED:
          //                if (++s_intv_cnt >= 2) { // was 10
          //                    log_i("a2dp media stopping...");
          //                    esp_a2d_media_ctrl(ESP_A2D_MEDIA_CTRL_STOP);
          //                    m_media_state = APP_AV_MEDIA_STATE_STOPPING;
          //                    s_intv_cnt = 0;
    case APP_AV_MEDIA_STATE_STOPPING:
          if (a2d->media_ctrl_stat.cmd == ESP_A2D_MEDIA_CTRL_STOP && a2d->media_ctrl_stat.status == ESP_A2D_MEDIA_CTRL_ACK_SUCCESS) {
            esp_a2d_source_disconnect(s_peer_bda);
            m_a2d_state = APP_AV_STATE_DISCONNECTING;
  print_status();
void bt_app_av_state_connected(uint16_t event, void *param) {
  switch (event) {
          // log_i("a2dp disconnected");
          esp_bt_gap_set_scan_mode(ESP_BT_CONNECTABLE, ESP_BT_GENERAL_DISCOVERABLE);
        if (ESP_A2D_AUDIO_STATE_STARTED == a2d->audio_stat.state) {
          //s_pkt_cnt = 0;
      // not suppposed to occur for A2DP source
      bt_app_av_media_proc(event, param);
    default:
void bt_app_av_state_disconnecting(uint16_t event, void *param) {
  switch (event) {
    default:
int get_APP_AV_STATE() {
  return m_a2d_state;
bool a2dp_source_init(String deviceName, String pinCode) {
  print_status();
  esp_err_t res;
  s_BT_sink_name = deviceName;
  int s_pin_code_length = pinCode.length();
  for (int i = 0; i < s_pin_code_length; i++)
    s_pin_code[i] = pinCode[i];
  do {  // release controller memory
    res = esp_bt_controller_mem_release(ESP_BT_MODE_BLE);
  } while (res == 0);
  if (!btStart()) {
    log_e("Failed to initialize controller");
    return false;
  } else log_i("controller initialized");
  res = esp_bluedroid_init();  // init bluedroid
  if (res != ESP_OK) {
    log_e("initialize bluedroid failed");
    return false;
  res = esp_bluedroid_enable();  // activate bluedroid
    log_e("enable bluedroid failed");
    return false;
  m_bt_enabled = true;
  /* Bluetooth device name, connection mode and profile set up */
  esp_bt_dev_set_device_name(BT_DEVICE_NAME.c_str()); /* set up device name */
  esp_bt_gap_register_callback(bt_app_gap_cb);        /* register GAP callback function */
  esp_a2d_register_callback(&bt_app_a2d_cb);          /* initialize A2DP source */
  esp_a2d_source_register_data_callback(bt_app_a2d_data_cb);
  esp_a2d_source_init();
  esp_bt_gap_set_scan_mode(ESP_BT_CONNECTABLE, ESP_BT_GENERAL_DISCOVERABLE); /* set discoverable and connectable mode */
  m_a2d_state = APP_AV_STATE_DISCOVERING;                                    /* start device discovery */
  m_hb_enabled = true;
  // Set default parameters for Legacy Pairing, use variable pin, input pin code when pairing
  esp_bt_pin_type_t pin_type = ESP_BT_PIN_TYPE_VARIABLE;
  esp_bt_gap_set_pin(pin_type, 0, pin_code);
  return true;
void print_status() {
  static int old_a2d_state = -1;
  static int old_media_state = -1;
  char ad2_state[7][14] = { "idle", "discovering", "discovered", "unconnected", "connecting", "connected", "disconnecting" };
  char media_state[7][9] = { "idle", "starting", "started", "stopping" };
  if (m_a2d_state != old_a2d_state) {
    if (old_a2d_state != -1) BT_INFO("bt_state: %s --> %s", ad2_state[old_a2d_state], ad2_state[m_a2d_state]);
    old_a2d_state = m_a2d_state;
  if (m_media_state != old_media_state) {
    if (old_media_state != -1) BT_INFO("media_state: %s --> %s", media_state[old_media_state], media_state[m_media_state]);
    old_media_state = m_media_state;
int32_t bt_app_a2d_data_cb(uint8_t *data, int32_t len) {  // BT data event
  uint32_t dataLength = 0;
  uint32_t sampleRate = 0;
  if (bt_data) dataLength = bt_data(data, len, &sampleRate);
  static uint8_t i = 0;
  if (sampleRate != 44100) log_e("SampleRate must be 44100");
  // todo scale sampleRate
  return dataLength;
I just coppied this from github link (a2dp_source.cpp)
Even though the developer advertises it as "Arduino", this is not actually an Arduino project. That makes it unfriendly for Arduino users. The cause of the error is that you are trying to compile the library code as if it was a complete program.
I'll provide instructions you can follow to use it:
  1. Select File > Preferences... (or Arduino IDE > Settings... for macOS users) from the Arduino IDE menus.
    The "Preferences" dialog will open.
  2. Take note of the path shown in the "Sketchbook location" field of the dialog.
  3. Click the "CANCEL" button.
    The "Preferences" dialog will close.
  4. Click the following link to open the library's GitHub repository homepage in your web browser:
    https://github.com/schreibfaul1/ESP32_A2DP_Source
  5. Click the "Code ▾" button you see on that page.
  6. Select Download ZIP from the menu.
    A download of the ZIP file of the library will start.
  7. Wait for the download to finish.
  8. Extract the downloaded file.
  9. Rename the src subfolder of the extracted folder to ESP32_A2DP_Source.
    This step is not absolutely necessary, but you might be confused later if we left the folder with the generic src name. Using a descriptive name makes it clear what the folder contains at a glance.
  10. Copy the ESP32_A2DP_Source folder from the extracted folder to the libraries subfolder of the path you saw in the "Sketchbook location" preference.
    The folder structure of the installation must look like this:
    <Sketchbook location>/
    ├── libraries/
    │   ├── ESP32_A2DP_Source/
    │   │   ├── a2dp_source.h
    (where <Sketchbook location> is the path from the Sketchbook location" preference)
  11. Rename the file main.cpp in the examples/SD_Card subfolder of the extracted folder to SD_Card.ino
  12. Select File > Open... from the Arduino IDE menus.
  13. Select the examples/SD_Card/SD_Card.ino file from the extracted folder in the dialog.
  14. Click the "Open" button.
  15. Select your ESP32 board from the Tools > Board menu in Arduino IDE.
  16. Compile or upload the sketch.
Hopefully this time the sketch will compile without any errors.
The instructions above are for the "SD_Card" example program that was included with the project. You can study the code in that example to learn how to use the library and adapt it to your project. If you want to use the microphone, you can check out the "BT_Microphone" example provided with the project. You will need to do the same renaming procedure as you did for the "SD_Card" example (except this time naming examples/BT_Microphone/main.cpp to BT_Microphone.ino) to make it a valid Arduino sketch.
I made all of this things, but IDE gaved error. i checked, and files .h and .cpp became note file.
i dont know how turn them back
Please provide the full and exact text of the error in a reply here.
