Connecting external antenna
I have a very basic question of connecting an external antenna to a 433 receiver.
I have an Aurel RX-4M50RR30SF receiver, to which I’d like to connect T433,92 AUREL whip antenna.
Pin 3 of the receiver is marked as antenna, so should I connect pin 3 to antennas core wire and that’s it ?
Antenna comes with a red ground wire - should it be connected anywhere ? I’m quite lost basically :).
Receiver: http://www.soselectronic.com/?str=371&artnum=50289&name=aurel-rx-4m50rr30sf
Antenna: http://www.soselectronic.com/?str=371&artnum=50287&name=aurel-t433-92
Thanks,
Lauris
I would have gotten the antenna with the coax lead. Use the red lead to connect the base of the antenna to pin 2 (Ground) of the radio.
Thanks John.
