Looking at schematic for APM (w/ ATmega 2560) I think what's labelled as "OUT5" on the APM Board is Arduino Pin 8. True?
I hook up a servo to OUT5. Then in only one place I change the follow bundled sketch. I change from attaching pin 9 to attaching pin 8. The servo works on another board, noprob. Why doesn't this work?
// Sweep
// by BARRAGAN http://barraganstudio.com
// This example code is in the public domain.#include <Servo.h>
Servo myservo; // create servo object to control a servo
// a maximum of eight servo objects can be createdint pos = 0; // variable to store the servo position
myservo.attach(9); // attaches the servo on pin 9 to the servo object
}void loop()
for(pos = 0; pos < 180; pos += 1) // goes from 0 degrees to 180 degrees
{ // in steps of 1 degree
myservo.write(pos); // tell servo to go to position in variable 'pos'
delay(15); // waits 15ms for the servo to reach the position
for(pos = 180; pos>=1; pos-=1) // goes from 180 degrees to 0 degrees
