hi everyone
i recently bought the HY -SRF 05 sensor but cant connect it to the arduino uno.
here the code im using
Tested with HY-SRF05, HC-SR04
Assuming a room temp of 20 degrees centigrade
The circuit:
- VVC connection of the sensor attached to +5V
- GND connection of the sensor attached to ground
- TRIG connection of the sensor attached to digital pin 12
- ECHO connection of the sensor attached to digital pin 13
const int TRIG_PIN = 12;
const int ECHO_PIN = 13;
// initialize serial communication:
pinMode(TRIG_PIN,OUTPUT);
pinMode(ECHO_PIN,INPUT);
long duration, distanceCm, distanceIn;
// Give a short LOW pulse beforehand to ensure a clean HIGH pulse:
digitalWrite(TRIG_PIN, LOW);
delayMicroseconds(2);
digitalWrite(TRIG_PIN, HIGH);
delayMicroseconds(10);
duration = pulseIn(ECHO_PIN,HIGH);
// convert the time into a distance
distanceCm = duration / 29.1 / 2 ;
distanceIn = duration / 74 / 2;
if (distanceCm <= 0){
Serial.println("Out of range");
else {
Serial.print(distanceIn);
Serial.print("in, ");
Serial.print(distanceCm);
Serial.print("cm");
i connected the trig to digital pin 12 and the echo to pin 13 the vcc to 5v but when i connect the ground the the ground on the arduino it switches off
any reason why this happens .......... thanks
