Connecting i2c IMU "Sensor Stick sensor"
Hi everyone,
I’m hoping some1 can help me with the communication between my new sparkfun sensor (9DOF Sensor Stick :- https://www.sparkfun.com/products/10724 … datasheet within this link) and my Arduino. I’m quite new to programming so advice would be much apreciated. So far this is the code I have:
#include <Wire.h>
#define  ADXL345_ADDRESS (0xA6 >> 1)
//There are 6 data registers, they are sequential starting
//with the LSB of X.  We'll read all 6 in a burst and won't
//address them individually
#define ADXL345_REGISTER_XLSB (0x32)
 //Need to set power control bit to wake up the adxl345
 #define ADXL_REGISTER_PWRCTL (0x2D)
 #define ADXL_PWRCTL_MEASURE (1 << 3)
#define ITG3200_ADDRESS (0xD0 >> 1)
//request burst of 6 bytes from this address
#define ITG3200_REGISTER_XMSB (0x1D)
#define ITG3200_REGISTER_DLPF_FS (0x16)
#define ITG3200_FULLSCALE (0x03 << 3)
#define ITG3200_42HZ (0x03)
#define HMC5843_ADDRESS (0x3C >> 1)
//First data address of 6 is XMSB.  Also need to set a configuration register for
//continuous measurement
 #define HMC5843_REGISTER_XMSB (0x03)
 #define HMC5843_REGISTER_MEASMODE (0x02)
 #define HMC5843_MEASMODE_CONT (0x00)
void i2c_write(int address, byte reg, byte data) {
  // Send output register address
  Wire.beginTransmission(address);
  Wire.write(reg);
  // Connect to device and send byte
  Wire.write(data); // low byte
  Wire.endTransmission();
void i2c_read(int address, byte reg, int count, byte* data) {
 int i = 0;
 // Send input register address
 Wire.write(reg);
 // Connect to device and request bytes
 Wire.requestFrom(address,count);
 while(Wire.available()) // slave may send less than requested {
   char c = Wire.read(); // receive a byte as character
data[i] = c;
i++;
void init_adxl345() {
  byte data = 0;
  i2c_write(ADXL345_ADDRESS, ADXL_REGISTER_PWRCTL, ADXL_PWRCTL_MEASURE);
  //Check to see if it worked!
  i2c_read(ADXL345_ADDRESS, ADXL_REGISTER_PWRCTL, 1, &data);
  Serial.println((unsigned int)data);
int accelerometer_data[3];
void read_adxl345() {
 byte bytes[6];
 memset(bytes,0,6);
 //read 6 bytes from the ADXL345
 i2c_read(ADXL345_ADDRESS, ADXL345_REGISTER_XLSB, 6, bytes);
 //now unpack the bytes
 for (int i=0;i<3;++i) {
 accelerometer_data[i] = (int)bytes[2*i] + (((int)bytes[2*i + 1]) << 8);
void init_itg3200() {
  byte data = 0;
  //Set DLPF to 42 Hz (change it if you want) and
  //set the scale to "Full Scale"
  i2c_write(ITG3200_ADDRESS, ITG3200_REGISTER_DLPF_FS, ITG3200_FULLSCALE | ITG3200_42HZ);
  //Sanity check! Make sure the register value is correct.
  i2c_read(ITG3200_ADDRESS, ITG3200_REGISTER_DLPF_FS, 1, &data);
int gyro_data[3];
void read_itg3200() {
  byte bytes[6];
  memset(bytes,0,6);
  //read 6 bytes from the ITG3200
  i2c_read(ITG3200_ADDRESS, ITG3200_REGISTER_XMSB, 6, bytes);  //now unpack the bytes
  gyro_data[i] = (int)bytes[2*i + 1] + (((int)bytes[2*i]) << 8);
void init_hmc5843() {
  byte data = 0;
  //set up continuous measurement
  i2c_write(HMC5843_ADDRESS, HMC5843_REGISTER_MEASMODE, HMC5843_MEASMODE_CONT);
  //Sanity check, make sure the register value is correct.
  i2c_read(HMC5843_ADDRESS, HMC5843_REGISTER_MEASMODE, 1, &data);
int magnetometer_data[3];
 byte bytes[6];
 memset(bytes,0,6);
  //read 6 bytes from the HMC5843
 i2c_read(HMC5843_ADDRESS, HMC5843_REGISTER_XMSB, 6, bytes);
 magnetometer_data[i] = (int)bytes[2*i + 1] + (((int)bytes[2*i]) << 8);
  Wire.begin();
  for(int i = 0; i < 3; ++i) {
    accelerometer_data[i] = magnetometer_data[i] = gyro_data[i] = 0;
  init_adxl345();
  init_hmc5843();
  init_itg3200();
   read_adxl345();
   Serial.print("ACCEL: ");
   Serial.print(accelerometer_data[0]);
   Serial.print("\t");
   Serial.print(accelerometer_data[1]);
   Serial.print("\t");
   Serial.print(accelerometer_data[2]);
   Serial.print("\n");
   read_hmc5843();
   Serial.print("MAG: ");
   Serial.print(magnetometer_data[0]);
   Serial.print(",");
   Serial.print(magnetometer_data[1]);
   Serial.print(",");
   Serial.print(magnetometer_data[2]);
   Serial.print("\n");
   read_itg3200();
   Serial.print("GYRO: ");
   Serial.print(gyro_data[0]);
   Serial.print("\t");
   Serial.print(gyro_data[1]);
   Serial.print("\t");
   Serial.print(gyro_data[2]);
   Serial.print("\n");
   //Sample at 10Hz
   delay(100); }
And this is the error I recieve:
sketch_jan21b.cpp: In function ‘void i2c_read(int, byte, int, byte*)’:
sketch_jan21b:48: error: ‘c’ was not declared in this scope
sketch_jan21b.cpp: At global scope:
sketch_jan21b:51: error: expected constructor, destructor, or type conversion before ‘.’ token
sketch_jan21b:52: error: expected declaration before ‘}’ token
I was wondering if there was too much code here for merely setting up communication with and getting values from the sensors. It seems to me that there is an abundance of code here, but as I say Im not very code savvy and have pieced the above code together from various sources of help but am finally stumped.
Thanks in advance for any help/ advice that comes this way.
I haven’t looked over the code but the following will fix your reported compiler error.
  int i = 0;
  char c;
  Wire.write(reg);
  while(Wire.available()) { // slave may send less than requested
    data[i] = c;
    i++;
@mkwired Thanks for the help!!! I really appreciate it!
