Connecting LCD to NANO on the mini board
Hello, i have the usual beginner LCD screen with 16 pins, NANO, which has of course 15 pins on one side and a mini board with 30 pins in one row. Now I have the problem with connecting it because one of the pins would have to be overlapped and I dont know if that would damage my NANO in any way. I have tried looking for answers on the web but havent found any I could understand. I did the picture of how I would connect it if that was possible...my dilemma is if I can connect 5V from NANO which has to go on VDD pin on LCD and on the picture those 5V will also be connected to Vin....
Your question is not clear.
If you are asking whether you can connect all the 5V together then the answer is yes.
So on this picture I showed how I would like to connect it ( ignore the ground cable ). The power supply would be USB which I didnt connect now. And the 5V exit from the NANO needs to be connected to the VDD of the LCD. So, can I connect it like this and plug the USB in?
Probably not a good idea. The Vin is connected to the voltage regulator input side, which is trying to produce 5V on the other side (see schematic https://www.arduino.cc/en/uploads/Main/ArduinoNano30Schematic.pdf)
Your best bet is a full size breadboard or a second short breadboard.
Another possibility is an I2C adapter for your LCD.
Don
Thank you very much for your quick answers, I already ordered the full size breadboard and its on its way but I wanted to play with the LCD. Guess I will have to wait for it to come :slight_smile:
