Connecting logic and motor power GND - advice please?
Hello All
I am building a simple motor controller using an SN754410 quad half-h bridge driver.
This driver is capable of accepting 2 voltages - for the logic and for the motors.
Now, assuming the power supply of the logic is seperate to the motor power supply, I guess I need to connect the two GND wires together.
It is my understanding that a motor can create noise on the line so I was wondering whether I should fit smoothing capacitors to between Vmot and GND and Vlogic and GND.
If so, what capacitance should these capacitors be? And why if possible.
Thanks
Yes see:- http://www.thebox.myzen.co.uk/Tutorial/Power_Supplies.html
Yes see:- http://www.thebox.myzen.co.uk/Tutorial/De-coupling.html
So they are big enough and cut out high frequencies typically use a 0.1uF and a 47uF
Thanks Guys. Usefull links Grumpy Mike :)
