Connecting Max7219/DS1307
Max7219 and DS1307 connection
The problem I have is that there is very little information on the web or the forum about connecting a single or a number of Max7219 8x8 Matrixes with an RTC module (DS1302/1307...).
I have been able to get the Max7219 displaying single letters/numerals and scrolling info across a number of Max7219, and getting a DS1307 to display time and date on 1602/2004 displays, but to connect the two very little or no information can be found, the closet is the Adafruit Ledbackpack but it only works with their sketch/software.
Any help or information with this problem would be greatly welcomed.
What information are you looking for? If you can get the date/time from the clock, and you can display text, what's everything you need to be able to do to display the date and/or time.
Post the code you have, and explain what is/is not working.
What I’m trying to achieve is to display at this stage is the time and date scrolling across the max7219 then to have the time stationary for a set period the back to a scrolling display.
The scrolling display works on its own, and time and date works on its own 1602 shield.
The problem I am having is the combining of the two functions to run on 5xMax7219.
If the letters and numerals are needed to be added for coding, these I have in binary or hex format.
[/#include <SPI.h>
#include <Wire.h>
#include "RTClib.h"
#include <Adafruit_GFX.h>
#include <Max72xxPanel.h>
int pinCS = 10; // Attach CS to this pin, DIN to MOSI and CLK to SCK (cf http://arduino.cc/en/Reference/SPI )
int numberOfHorizontalDisplays = 5;
int numberOfVerticalDisplays = 1;
Max72xxPanel matrix = Max72xxPanel(pinCS, numberOfHorizontalDisplays, numberOfVerticalDisplays);
RTC_DS1307 rtc;
String tape = "The Time is:        The Date is:";   // Need to insert Time and Date inbetween, then after delay Time is shown for a set period then repeated
int wait = 50; // In milliseconds
int spacer = 1;
int width = 5 + spacer; // The font width is 5 pixels
  matrix.setIntensity(0); // Use a value between 0 and 15 for brightness
  #ifdef AVR
  Wire.begin();
#else
  Wire1.begin(); // Shield I2C pins connect to alt I2C bus on Arduino Due
#endif
  rtc.begin();
 if (! rtc.isrunning()) {
    matrix.print("RTC is NOT running!");
    // following line sets the RTC to the date & time this sketch was compiled
    rtc.adjust(DateTime(__DATE__, __TIME__));
// Adjust to your own needs
//  matrix.setPosition(0, 0, 0); // The first display is at <0, 0>
//  matrix.setPosition(1, 1, 0); // The second display is at <1, 0>
//  matrix.setPosition(2, 2, 0); // The third display is at <2, 0>
//  matrix.setPosition(3, 3, 0); // And the last display is at <3, 0>
//  matrix.setRotation(0, 2);    // The first display is position upside down
//  matrix.setRotation(3, 2);    // The same hold for the last display
  for ( int i = 0 ; i < width * tape.length() + matrix.width() - 1 - spacer; i++ ) {
    matrix.fillScreen(LOW);
    int letter = i / width;
    int x = (matrix.width() - 1) - i % width;
    int y = (matrix.height() - 8) / 2; // center the text vertically
    while ( x + width - spacer >= 0 && letter >= 0 ) {
      if ( letter < tape.length() ) {
        matrix.drawChar(x, y, tape[letter], HIGH, LOW, 1);
      letter--;
      x -= width;
    matrix.write(); // Send bitmap to display
    DateTime now = rtc.now();
    matrix.setPosition(0,0,0);
    matrix.print(now.hour(), DEC);
    matrix.print(':');
    matrix.print(now.minute(), DEC);
    matrix.print(':');
    matrix.print(now.second(), DEC);
    matrix.print(now.day(), DEC);
    matrix.print('/');
    matrix.print(now.month(), DEC);
    matrix.print('/');
    matrix.print(now.year(), DEC);
    matrix.print(' ');
    delay(wait);
    delay(100);
code]
