Connecting more than one sensor to arduino
I am pretty new, to arduino. I have an arduino uno. I was wondering how I could connect more than one sensor and how can I open a serial monitor for each sensor I connect
Thanks
It's a flexiforce. I need to read more than I data at once.
You have 6 analog inputs on an Uno, you can read data from a flexiforce on each one, and send one message to the serial port for each, or one message showing the data for all 6, pretty easily.
So let's say I have I want to use 5 flexiforces. So initialize all 5 than loop for all 5?
Yes.
Initialaziation can just be:
// define pin names
byte flexiforce0 = A0;
byte flexiforce1 = A1;
byte flexiforce2 = A2;
byte flexiforce3 = A3;
byte flexiforce4 = A4;
// define variable to hold values
int force0;
int force1;
int force2;
int force3;
int force4;
than in loop:
force0 = analogRead(flexiforce0);
force1 = analogRead(flexiforce1);
force2 = analogRead(flexiforce2);
force3 = analogRead(flexiforce3);
force4 = analogRead(flexiforce4);
Serial.print ("Readings are: ");
Serial.print (force0);
Serial.print ("  ");
Serial.print (force1);
Serial.print ("  ");
Serial.print (force2);
Serial.print ("  ");
Serial.print (force3);
Serial.print ("  ");
Serial.print (force4);
Serial.println ("  ");
[code]
[/code]
