Connecting multiple clients with ESP8266
Hi all,
I've implemented a program that involves 3 ESP8266, 2 of them as clients and the other as a server. The program below, which is for the server, creates an array of WiFiClients that will be filled as soon as any of the clients are connected to the server. Connected clients send the server a string to turn on a led. The issue that I've encountered is in the instruction
if (NULL != clients[i] && clients[i]->available() )
Even though the client is connected and has sent the string to the server, it seems that "clients*->available()" is not able to read any bite so the if statement is false.*
What am I doing wrong?
*#include <ESP8266WiFi.h>
IPAddress local_IP(192,168,4,22);
IPAddress gateway(192,168,4,9);
IPAddress subnet(255,255,255,0);
WiFiServer server(3000);
#define MAX_CLIENTS 2
WiFiClient *clients[MAX_CLIENTS] = { NULL };
const int ledPin =2;      // the number of the LED pin
// initialize the LED pin as an output:
 pinMode(ledPin, OUTPUT);
 Serial.print("Setting soft-AP configuration ... ");
 Serial.println(WiFi.softAPConfig(local_IP, gateway, subnet) ? "Ready" : "Failed!");
 Serial.print("Setting soft-AP ... ");
 boolean result = WiFi.softAP("ESPsoftAP_01", "00000000");
 if(result == true)
   Serial.println("Ready");
   Serial.println("Failed!");
// Start the server
 server.begin();
 Serial.println(F("Server started"));
 WiFiClient newClient = server.available();
 // wait for a client (web browser) to connect
 if (newClient)
   Serial.println("\n[New client connected]");
   for (int i=0 ; i<MAX_CLIENTS ; i++) {
       if (NULL == clients[i]) {
           clients[i] = new WiFiClient(newClient);
     // read line by line what the client (web browser) is requesting
       String line = clients[i]->readStringUntil('\r');
       Serial.print(line);
       if (line.equals("accendi")){
         // turn LED on:
       digitalWrite(ledPin, HIGH);
       delay(2000);
       digitalWrite(ledPin, LOW);
// If you want to disconnect the client here, then do this:
       clients[i]->stop();
       delete clients[i];
       clients[i] = NULL;
       Serial.println("[Client disconnected]");
   delay(1);// give the web browser time to receive the data
"newClient" will only be valid until "loop()" exits, I'm not sure if you can store the client in an array as you do. You should try to check wheter "clients[index]->connected()" returns non-zero for a valid client.
