I'd like to use the Arduino to build a low-cost MIDI controller.
I'd like to use an LCD module to label each control, but the number of controls exceeds the width of LCD modules I can find.
I'll need to connect multiple LCD modules to get enough characters to label each control adequately. Is it possible to do this?
I'd thought perhaps that using a multiplexer might be a good idea to route the arduino serial output between the LCDs - but I worry about timing problems (especially since I'll need to send MIDI too).
Nope, sorry, it's not possible. You'll just have to give up your dream ;D
There are a couple of ways you could go: you could connect all the LCDs in parallel, and run a separate line to the "E" pin on each one. Or you could use I2C (either with a specialized LCD controller board, or one of the "port expander" chips, like this), and assign a different I2C address to each LCD.
I like the "in parallel, with enable lines" approach. I might try this with a demultiplexer. I've read scary things about I2C - but that was around 5-6 years ago, so perhaps things are a little easier now.
I'm almost certain there won't be enough arduino pins to support all the buttons I require so I'll have to do some multiplexing somewhere. Maybe I2C could help in that regard too.
