Connecting Multiple led's to Arduino.. Max Led's without Frying chip.
i wanted to connect the multiple led's to the arduino on each pin.
if i connect 10 led's to pins 3 to 13 on the Arduino with resistor 300 ohms, does it damage the chip?
The pins are rated to a max of 40mA so you can do so safely.
Weedpharma
weedpharma:
Weedpharma
true, but keep in mind that 40mA per pin is an absolute max, and that there are other current limitations related to ports - For axample, you can't safely drive simultaneously 8 Leds at 30mA connecting them at D0-D7 pins , because you'd ask 240mA on a port which can source max 150mA .
Have a look here
The small SMD LED’s on the Arduino boards are modern Hi-sensitive LED’s, which only requires some 2-3mA to light up very bright.
This is done with a 1K (1000) ohms resistor.
If you are using same kind of LED’s, you will not need a 330 ohm resistor, which will provide around some 8mA through the LED.
Mind you he said 10 LEDs, and 330 ohms gives 8 to 10 mA each, total if all lit no more than 100 mA so it should be fine (if the LEDs are the only thing drawing any significant current). :grin:
Mind you that LED's are non-linear components, not obeying Ohms law.
Then it is really impossible to predict what will happen, if you try calculate a resistor.
It may blow up, because of un-predicted behaviour, as we are dealing with an undefinded component here.
Until we solve that, I believe everyone should keep hands off LED's and resistors, as they wont know what they are doing, by definition. :smiling_imp:
I and several other people have attached several LEDs to the Arduino without damaging anything. I think you'll be alright :slight_smile:
Squirt_5432:
Lucky fellas -
Ya dont even know the theory behind them working LEDs ::slight_smile:
Table 30.1 on page 313 of the [u]Atmel Datasheet[/u] says 40mA absolute maximum per pin, or 200mA absolute maximum total.
[u]Ohm's Law[/u] says Current = Voltage/Resistance.
Don't forget the voltage drop across the LED (check the LED's data sheet if you want to be 100% sure). With ~2V across the LED there is 3V across the resistor. With 3V across 300 Ohms, that's 10mA per LED. 10 LEDs @ 10mA would be well within spec.
You are assuming that LED's comply with Ohms law.
They dont, as they are non-linear components.
If you mix linear and non-linear components and apply Ohms law, you will get an un-predictable result, as the theory behind is not documented.
You are on dangerous grounds.
How will you know that he LED is not radiating Gamma rays then ?
Or even death rays ?
Ah well, life is dangerous ... :smiling_imp:
Not a funny joke.
Ohm's law always works and LED's can't emit death rays, even if you drop them into the sun.
MorganS:
Not a funny joke.
How con you be so sure ?
The atmega chip is also a nonlinear component, which does not comply to ohm's law.
Ohms law discussion - be warned !
