I’m working on a project with an Arduino UNO, ethernet shield, and multiple sensors.
My question is in regards to the 5V connection…
I have the 5V connection running from the Arduino to the breadboard. Then I have all the sensors plugged in to the same 5v connection through the breadboard.
Am I wiring the sensors correctly to the 5V? Do they all share the same 5V connection like shown in the picture?
I have three sensors: air temperature, soil moisture, and water level
The reason I’m asking about the 5V is because when I dip the soil moisture sensor into the water the air temperature also rises immediately (and it rises a lot)! That doesn’t make sense to me…
#include <SPI.h>
#include <Ethernet.h>
// MAC address from Ethernet shield sticker under board
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
IPAddress ip(222,338,1,XX); // IP address, may need to change depending on network
EthernetServer server(80); // create a server at port 80
String HTTP_req; // stores the HTTP request
Ethernet.begin(mac, ip); // initialize Ethernet device
server.begin(); // start to listen for clients
Serial.begin(9600); // for diagnostics
pinMode(13, INPUT); // switch is attached to Arduino pin 13
EthernetClient client = server.available(); // try to get client
if (client) { // got client?
boolean currentLineIsBlank = true;
while (client.connected()) {
if (client.available()) { // client data available to read
char c = client.read(); // read 1 byte (character) from client
HTTP_req += c; // save the HTTP request 1 char at a time
// last line of client request is blank and ends with \n
// respond to client only after last line received
if (c == '\n' && currentLineIsBlank) {
// send a standard http response header
client.println("Content-Type: text/html");
client.println("Connection: keep-alive");
client.println();
// AJAX request for switch state
if (HTTP_req.indexOf("ajax_switch") > -1) {
// read switch state and send appropriate paragraph text
GetSwitchState(client);
else { // HTTP request for web page
// send web page - contains JavaScript with AJAX calls
client.println("<!DOCTYPE html>");
client.println("<html>");
client.println("<head>");
client.println("<title>Arduino Web Page</title>");
client.println("<script>");
client.println("function GetSwitchState() {");
client.println("nocache = \"&nocache=\"\
+ Math.random() * 1000000;");
client.println("var request = new XMLHttpRequest();");
client.println("request.onreadystatechange = function() {");
client.println("if (this.readyState == 4) {");
client.println("if (this.status == 200) {");
client.println("if (this.responseText != null) {");
client.println("document.getElementById(\"switch_txt\")\
.innerHTML = this.responseText;");
client.println("}}}}");
client.println(
"request.open(\"GET\", \"ajax_switch\" + nocache, true);");
client.println("request.send(null);");
client.println("setTimeout('GetSwitchState()', 1000);");
client.println("}");
client.println("</script>");
client.println("</head>");
client.println("<body onload=\"GetSwitchState()\">");
client.println("<h1>Arduino Aquaponics System Status</h1>");
client.println(
"<p id=\"switch_txt\">Loading data...</p>");
client.println("</body>");
client.println("</html>");
// display received HTTP request on serial port
Serial.print(HTTP_req);
HTTP_req = ""; // finished with request, empty string
// every line of text received from the client ends with \r\n
if (c == '\n') {
// last character on line of received text
// starting new line with next character read
else if (c != '\r') {
// a text character was received from client
currentLineIsBlank = false;
} // end if (client.available())
} // end while (client.connected())
delay(1); // give the web browser time to receive the data
client.stop(); // close the connection
} // end if (client)
// send the state of the switch to the web browser
void GetSwitchState(EthernetClient cl)
cl.print("<h2>Sensors</h2>");
int airTemp;
airTemp = analogRead(0);
// Cnvert ADC reading to voltage
float voltage = (airTemp/1024.0 * 5.0);
Serial.print("Volts: ");
Serial.print(voltage);
Serial.print("\n");
// Convert the voltage to temperature in degrees celsius
float temperature = ((voltage - 0.5) * 100);
Serial.print("Temperature C: ");
Serial.print(temperature);
Serial.print("\n");
// Convert celsius into farenheight
float temperatureF = ( ( (temperature * 9) / 5) + 32);
cl.print("<p>Air Temp: ");
cl.print(temperatureF);
cl.println("</p>");
int waterLevel;
waterLevel = analogRead(1);
cl.print("<p>Water Level: ");
cl.print(waterLevel);
cl.println("</p>");
int soilMoisture;
soilMoisture = analogRead(2);
cl.print("<p>Soil Moisture: ");
cl.print(soilMoisture);
cl.println("</p>");
