I have connected device in this format. I am testing basic interactive code with bluetooth. If i send string
from '1' serially it wont respond led will not turn on . How can i use this device
if i disconnect TX and RX it will start working . means it print data. if i connected with hardware it didnt worked
int LED = D1;
pinMode(LED, OUTPUT);
Serial.begin(115200); /* Define baud rate for serial communication */
Serial.println("welcome");
if (Serial.available()) /* If data is available on serial port */
char data_received;
data_received = Serial.read(); /* Data received from bluetooth */
if (data_received == '1')
digitalWrite(LED, HIGH);
Serial.write("LED turned ON\n");
else if (data_received == '2')
digitalWrite(LED, LOW);
Serial.write("LED turned OFF\n");
Serial.write("Select either 1 or 2");
Select either 1 or 2LED turned ON
Select either 1 or 2Select either 1 or 2Select either 1 or 2Select either 1 or 2Select either 1 or 2Select either 1 or 2
