Connecting OBDII adapter to different serial port?
I'm not sure if this is the right forum for this.
I have the OBDII adapter here: Freematics OBD-II Adapter for Arduino | ArduinoDev.com
I am running this on a Mega, and want to connect the OBD adapter to a different serial port. Nowhere in the initialization do you have to define which port it's connected to. How do i define which port it's connected to?
Mike
Without seeing your code how can we know ?
...R
I don't really have code yet.
Here's the default code provided on the OBD-II adapter page. Nowhere does it define which port the device uses.
#include <Wire.h>
#include <obd.h>
COBD obd; /* for Model A (UART version) */
  // we'll use the debug LED as output
  pinMode(13, OUTPUT);
  // start communication with OBD-II adapter
  obd.begin();
  // initiate OBD-II connection until success
  while (!obd.init());
  int value;
  // save engine RPM in variable 'value', return true on success
  if (obd.read(PID_RPM, value)) {
    // light on LED on Arduino board when the RPM exceeds 3000
    digitalWrite(13, value > 3000 ? HIGH : LOW);
mike944:
Then you will have to delve into the entrails of the OBD library.
...R
