Connecting RF transmitter and receiver pair to arduino
I got this RF tx and rx pair: http://www.bitsbox.co.uk/sensors.html (scroll to the bottom)
here is the datasheet for the transmitter: http://www.bitsbox.co.uk/data/AMRT4_433.pdf
here is the datasheet for the receiver: http://www.bitsbox.co.uk/data/AM-HRR433.pdf
Can someone please guide me as to how i cant connect them to the arduinos and a simple example code maybe?
Thanks in advance.
What do you want to do with them?
I want to control 4 relays. ill have 2 arduinos, one on the tx side one on the rx side.
Those are OOK (On-Off Keying) modules, I believe. This is like old time Morse code.. There is noise in between on-off signals.
There is an Arduino library that is often used: http://www.open.com.au/mikem/arduino/VirtualWire.pdf The library: http://www.open.com.au/mikem/arduino/VirtualWire-1.9.zip
OOK (Sometime called ASK (Amplitude Shift Keying) ) requires the receiver to be synchronized with the transmitter for each burst of data.
Power/Relay stuff (One the RF works!) is here: http://arduino-info.wikispaces.com/ArduinoPower
You can use normal serial protocols with those units, but only up to about 2400 bits per second, and slower is better.
For resilience, you could try something like R/C PPM, where you would send the state of all the relays say 20 times a second encoded as a pulse width, and only change the state of the relay if you saw the same state in consecutive packets. Pulses would be, say 1 or 2 ms separated by a 1ms gap, with a much longer gap between packets.
I think you can do this more easily with a pair of XBees and you might not even need your Arduinos.
Don
Thnaks everyone for your help.
That seems so difficult :/. anyway i have connected them to 2 arduinos and they are working! i have used a very easy approach. i send a word as an array and on the receiver side i just compare it in an if statement. it works perfectly. Are there any disadvantage of using this method?
Noise from number 47's wireless doorbell? I don't know, I can't see your code.
#include <VirtualWire.h>
int check2 = 1;
char buttn1[8] = {"relay 1"} ;
    Serial.println("setup");
    vw_set_ptt_inverted(true);
    vw_setup(2000);
    vw_rx_start();
    uint8_t buf[VW_MAX_MESSAGE_LEN];
    uint8_t buflen = VW_MAX_MESSAGE_LEN;
    if (vw_get_message(buf, &buflen))
	int i;
	Serial.print(check2);
	for (i = 0; i < buflen; i++)
	    Serial.print(buf[i]);
	Serial.println("");
if (buttn1[6] == buf [6] && check2 == 1){
  digitalWrite(13,HIGH);
check2 = 0;
 if ( buttn1[6] != buf [6] && check2 ==  0 ) {
check2 = 2;
 if ( buttn1[6] == buf [6] && check2 ==  2 ) {
  digitalWrite(13,LOW);
check2 = 3;
 if ( buttn1[6] != buf [6] && check2 ==  3 ) {
check2 = 1;
I know its pretty bad, but it works fine. i just compare the integer “1” . The check var is just to get a special button press action.
Bad?
It cannot even compile.
Closing brace for setup?
Just wanted to drop in my 2 cents. I am using RF Transmitter/Receiver pairs much like those, but from SparkFun.com
SparkFun Search Results: http://www.sparkfun.com/search/results?term=RF+link&what=products
I am using the 315MHz versions.
I am using them at my motel to relay signals when a door sensor is tripped (a potential guest or other person opens up one of the two office doors). Once any of the sensors are tripped, the Arduino Mega transmits a specific message via the RF Link Transmitter. While the SparkFun page states 5V supply, it can handle 1.5V - 12V. I am feeding the transmitter 9V directly from the VIN port of the arduino. More power = more range and signal strength.
The receivers are connected to remote boxes along side a Radio Shack 75dB chime and piezo buzzer. The chime is for when the office/lobby doors are opened, and the piezo is for other status messages. If the door(s) are open for 3 minutes (guest didn't shut it all the way), it makes an alternating higher pitched buzz. I have other status messages as well, but as of yet haven't fully implemented them for regular use.
I have only run into one or two instances where one of the remote chimes rang on its own without the door opening, so it could have been that I simply didn't have the transmitted control code/message long enough and some random noise just happened to match the overall message. I have since increased the size of the control code/message and have not run into an issue since.
The VirtualWire PDF mentioned above helped out greatly.
Hey, you did that programation, i need to know how two connect two arduinos too, i want to control 10 servos by 10 potentiometres via bluethoot, i have the master bluetooth and the slave
