Connecting sd card and bmp280 via spi interface
hello good people , the code is now running but i'm not able to interface both the bmp280 and sd card via spi communication protocol. only one of the devices is working. if i disconnect the barometer, the sd card is working but once i connect it , only the barometer works and not the sd card . here is the link to the project interface - Wokwi ESP32, STM32, Arduino Simulator
have a read of how-to-get-the-best-out-of-this-forum
confirm:
  1. what microcontroller you are using, e.g. 38pin ESP32
  2. what devices you wish to connect
any particular reason to connect BMP280 using SPI - why not I2C
  1. i'm using esp32 30 pins wokwi-esp32-devkit-v1, it's visible when you click the project link,
  2. i want to connect bmp280 and sd card via spi interface
  3. currently the wokwi doesn't support the bmp sensor so a custom chip was used and it only implements spi and not i2c
Provide a link to or a picture of the SD card adapter you are using.
you can open the project directly with the wokwi link interface - Wokwi ESP32, STM32, Arduino Simulator
using the ESP32 NodeMCU I have connected a SD card to the VSPI interface (pins 23 MOSI 19 MISO 18 CLK and 5 CS) and a MFRC522 RFID reader to the HSPI interface using pins
// default HSPI pins used by MFRC522 RFID reader
#define HSPI_SCK 14
#define HSPI_MISO 12
#define HSPI_MOSI 13
#define HSPI_CS 15
would be worth trying connecting the BMP280 to the HSPI pins (using VSPI for the SD card) of the wokwi-esp32-devkit-v1?
the complete code using VSPI and HSPI is
// ESP32 - SD card using VSPI MFRC522 RFID reader using HSPI
// see https://forum.arduino.cc/t/esp32-initialize-hspi-as-default-spi/1155093/12
/* original SD code from
  Rui Santos
  Complete project details at https://RandomNerdTutorials.com/esp32-microsd-card-arduino/
#include "FS.h"
#include "SD.h"
#include "SPI.h"
// MFRC522 RFID reader
#include <MFRC522v2.h>
#include <MFRC522DriverSPI.h>
#include <MFRC522DriverPinSimple.h>
#include <MFRC522Debug.h>
#define HSPI_SCK 14
#define HSPI_CS 15
SPIClass *hspi = new SPIClass(HSPI);      // HSPI object used by MFRC522
MFRC522DriverPinSimple ss_1_pin(HSPI_CS);   // Configurable, take an unused pin, only HIGH/LOW required, must be different to SS 2.
MFRC522DriverSPI driver_1{ ss_1_pin, *hspi };
MFRC522 reader = driver_1;                // Create MFRC522 instance.
// ESP32 RTC
#include <ESP32Time.h>
ESP32Time rtc(3600);  // offset in seconds GMT+1
  delay(2000);
  Serial.println("Read MRFC522 RFID card save time and data to SD card");
  rtc.setTime(1609459200);  // initialise RTC 1st Jan 2021 00:00:00
  // setup SD card reader using VSPI
  if (!SD.begin()) {                       // mount card
    Serial.println("Card Mount Failed");
    return;
  uint8_t cardType = SD.cardType();
  if (cardType == CARD_NONE) {
    Serial.println("No SD card attached");
    return;
  Serial.print("SD Card Type: ");
  if (cardType == CARD_MMC) {
    Serial.println("MMC");
  } else if (cardType == CARD_SD) {
    Serial.println("SDSC");
  } else if (cardType == CARD_SDHC) {
    Serial.println("SDHC");
    Serial.println("UNKNOWN");
  uint64_t cardSize = SD.cardSize() / (1024 * 1024);
  Serial.printf("SD Card Size: %lluMB\n", cardSize);
  listDir(SD, "/", 0);
  Serial.printf("Total space: %lluMB\n", SD.totalBytes() / (1024 * 1024));
  Serial.printf("Used space: %lluMB\n", SD.usedBytes() / (1024 * 1024));
  // setup MRFC522 RFID reader using HSPI
  Serial.print("open MRFC522 RFID reader");
  reader.PCD_Init();  // Init MFRC522 card.
  MFRC522Debug::PCD_DumpVersionToSerial(reader, Serial);
  // check Serial input read or delete data file
  if (Serial.available()) {
    char ch = Serial.read();
    if (ch == 'p')
      readFile(SD, "/data.txt");
    if (ch == 'd')
      deleteFile(SD, "/data.txt");
  // check MFRC522 RFID reader
  if (reader.PICC_IsNewCardPresent() && reader.PICC_ReadCardSerial()) {
    Serial.print("\n");
    Serial.println(rtc.getTime("%A, %B %d %Y %H:%M:%S"));  // (String) returns time with specified format
    // Show some details of the PICC (that is: the tag/card).
    Serial.print(F(" Card UID:"));
    MFRC522Debug::PrintUID(Serial, reader.uid);
    Serial.print("  PICC type: ");
    MFRC522::PICC_Type piccType = reader.PICC_GetType(reader.uid.sak);
    Serial.println(MFRC522Debug::PICC_GetTypeName(piccType));
    // save card details to SD
    String s = rtc.getTime("%A, %d/%m/%Y %H:%M:%S") + " Card UID:";
    for (byte i = 0; i < reader.uid.size; i++) {
      char text[10] = { 0 };
      snprintf(text, 100, " 0x%2X", reader.uid.uidByte[i]);
      s += String(text);
    s += "  PICC type: " + String((const char *)MFRC522Debug::PICC_GetTypeName(piccType)) + "\n";
    appendFile(SD, "/data.txt", s.c_str());
    // Halt PICC.
    reader.PICC_HaltA();
    // Stop encryption on PCD.
    reader.PCD_StopCrypto1();
// ************** SD functions **************************
void listDir(fs::FS &fs, const char *dirname, uint8_t levels) {
  Serial.printf("Listing directory: %s\n", dirname);
  File root = fs.open(dirname);
  if (!root) {
    Serial.println("Failed to open directory");
    return;
  if (!root.isDirectory()) {
    Serial.println("Not a directory");
    return;
  File file = root.openNextFile();
  while (file) {
    if (file.isDirectory()) {
      Serial.print("  DIR : ");
      Serial.println(file.name());
      if (levels) {
        listDir(fs, file.name(), levels - 1);
      Serial.print("  FILE: ");
      Serial.print(file.name());
      Serial.print("  SIZE: ");
      Serial.println(file.size());
void createDir(fs::FS &fs, const char *path) {
  Serial.printf("Creating Dir: %s\n", path);
  if (fs.mkdir(path)) {
    Serial.println("Dir created");
    Serial.println("mkdir failed");
void removeDir(fs::FS &fs, const char *path) {
  Serial.printf("Removing Dir: %s\n", path);
  if (fs.rmdir(path)) {
    Serial.println("Dir removed");
    Serial.println("rmdir failed");
void readFile(fs::FS &fs, const char *path) {
  Serial.printf("\nReading file: %s\n", path);
  File file = fs.open(path);
  if (!file) {
    Serial.println("Failed to open file for reading");
    return;
  //Serial.print("Read from file: ");
  while (file.available()) {
    Serial.write(file.read());
  file.close();
void writeFile(fs::FS &fs, const char *path, const char *message) {
  Serial.printf("Writing file: %s\n", path);
  File file = fs.open(path, FILE_WRITE);
  if (!file) {
    Serial.println("Failed to open file for writing");
    return;
  if (file.print(message)) {
    Serial.println("File written");
    Serial.println("Write failed");
  file.close();
void appendFile(fs::FS &fs, const char *path, const char *message) {
  //Serial.printf("Appending to file: %s\n", path);
  File file = fs.open(path, FILE_APPEND);
  if (!file) {
    Serial.println("Failed to open file for appending");
    return;
    //Serial.println("Message appended");
    Serial.println("Append failed");
  file.close();
void renameFile(fs::FS &fs, const char *path1, const char *path2) {
  Serial.printf("Renaming file %s to %s\n", path1, path2);
  if (fs.rename(path1, path2)) {
    Serial.println("File renamed");
    Serial.println("Rename failed");
void deleteFile(fs::FS &fs, const char *path) {
  Serial.printf("Deleting file: %s\n", path);
  if (fs.remove(path)) {
    Serial.println("File deleted");
    Serial.println("Delete failed");
void testFileIO(fs::FS &fs, const char *path) {
  static uint8_t buf[512];
  size_t len = 0;
  uint32_t start = millis();
  uint32_t end = start;
  if (file) {
    len = file.size();
    size_t flen = len;
    start = millis();
    while (len) {
      size_t toRead = len;
      if (toRead > 512) {
        toRead = 512;
      file.read(buf, toRead);
      len -= toRead;
    end = millis() - start;
    Serial.printf("%u bytes read for %u ms\n", flen, end);
    file.close();
  if (!file) {
    return;
  size_t i;
  start = millis();
  for (i = 0; i < 2048; i++) {
    file.write(buf, 512);
  Serial.printf("%u bytes written for %u ms\n", 2048 * 512, end);
  file.close();
a run gave
ESP32 SD card test - note VCC to 5V
SD Card Type: SDHC
SD Card Size: 14992MB
Listing directory: /
  DIR : System Volume Information
  FILE: test.txt  SIZE: 1048576
  FILE: data.txt  SIZE: 891
Total space: 14984MB
Used space: 2MB
open MRFC522 RFID readerFirmware Version: 0x92 = v2.0
dDeleting file: /data.txt
File deleted
Friday, January 01 2021 01:00:14
 Card UID: ZZ XX FD C2  PICC type: MIFARE 1KB
Friday, January 01 2021 01:00:18
 Card UID: Z0 XF 62 1A  PICC type: MIFARE 1KB
Friday, January 01 2021 01:00:19
Friday, January 01 2021 01:00:22
Friday, January 01 2021 01:00:23
Friday, January 01 2021 01:02:30
p
Reading file: /data.txt
Friday, 01/01/2021 01:00:14 Card UID: 0xZZ 0xXX 0xFD 0xC2  PICC type: MIFARE 1KB
Friday, 01/01/2021 01:00:18 Card UID: 0xZ0 0xXF 0x62 0x1A  PICC type: MIFARE 1KB
Friday, 01/01/2021 01:00:19 Card UID: 0xZ0 0xXF 0x62 0x1A  PICC type: MIFARE 1KB
Friday, 01/01/2021 01:00:22 Card UID: 0xZZ 0xXX 0xFD 0xC2  PICC type: MIFARE 1KB
Friday, 01/01/2021 01:00:23 Card UID: 0xZZ 0xXX 0xFD 0xC2  PICC type: MIFARE 1KB
Friday, 01/01/2021 01:02:30 Card UID: 0xZ0 0xXF 0x62 0x1A  PICC type: MIFARE 1KB
Friday, January 01 2021 01:03:28
p
Friday, 01/01/2021 01:03:28 Card UID: 0xZZ 0xXX 0xFD 0xC2  PICC type: MIFARE 1KB
Ah well good luck.
One of the fairly common SD card adapters does not work with other devices on the SPI bus, lots of people have problems with them.
thanks
See this doc:
https://docs.espressif.com/projects/esp-idf/en/v5.0/esp32s2/api-reference/peripherals/sdspi_share.html
