#define TINY_GSM_MODEM_SIM800 // Modem is SIM800L
// Set serial for debug console (to the Serial Monitor, default speed 115200)
#define SerialMon Serial
// Set serial for AT commands
#define SerialAT Serial1
// Define the serial console for debug prints, if needed
#define TINY_GSM_DEBUG SerialMon
// set GSM PIN, if any
#define GSM_PIN ""
// Your GPRS credentials, if any
const char apn[] = ""; // APN (example: internet.vodafone.pt) use https://wiki.apnchanger.org
const char gprsUser[] = "";
const char gprsPass[] = "";
// SIM card PIN (leave empty, if not defined)
const char simPIN[] = "";
// MQTT details
//const char* broker = "40.77.64.56"; // Public IP address or domain name
//const char* topicTemperature = "esp/test";
const char* broker = "whma1.azure-devices.net";
const char* mqtt_user = "whma1.azure-devices.net/esp32";
const char* mqtt_pass = "SharedAccessSignature sr=whma1.azure-devices.net%2Fdevices%2Fesp32&sig=IX8GgNU3Hpt2wwkJn1MFn2VjSvmVUe66w2kGL9J2hAQ%3D&se=1663314510";
//#define DUMP_AT_COMMANDS
#include <Wire.h>
#include <TinyGsmClient.h>
#ifdef DUMP_AT_COMMANDS
#include <StreamDebugger.h>
StreamDebugger debugger(SerialAT, SerialMon);
TinyGsm modem(debugger);
#else
TinyGsm modem(SerialAT);
#endif
#include <PubSubClient.h>
TinyGsmClient client(modem);
PubSubClient mqtt(client);
// TTGO T-Call pins
#define MODEM_RST 5
#define MODEM_PWKEY 4
#define MODEM_POWER_ON 23
#define MODEM_TX 27
#define MODEM_RX 26
#define I2C_SDA 21
#define I2C_SCL 22
// BME280 pins
#define I2C_SDA_2 18
#define I2C_SCL_2 19
#define OUTPUT_1 2
#define OUTPUT_2 15
uint32_t lastReconnectAttempt = 0;
float temperature = 0;
long lastMsg = 0;
void mqttCallback(char* topic, byte* message, unsigned int len) {
Serial.print("Message arrived on topic: ");
Serial.print(topic);
Serial.print(". Message: ");
String messageTemp;
for (int i = 0; i < len; i++) {
Serial.print((char)message[i]);
messageTemp += (char)message[i];
boolean mqttConnect() {
SerialMon.print("Connecting to ");
SerialMon.print(broker);
// Connect to MQTT Broker without username and password
// boolean status = mqtt.connect("GsmClientN");
// Or, if you want to authenticate MQTT:
boolean status = mqtt.connect("GsmClientN", mqtt_user, mqtt_pass);
if (status == false) {
SerialMon.println(" fail");
ESP.restart();
return false;
SerialMon.println(" success");
return mqtt.connected();
// Set console baud rate
SerialMon.begin(115200);
delay(10);
// Start I2C communication
// Set GSM module baud rate and UART pins
SerialAT.begin(115200, SERIAL_8N1, 33, 25);
delay(6000);
// Restart takes quite some time
// To skip it, call init() instead of restart()
SerialMon.println("Initializing modem...");
modem.restart();
// modem.init();
String modemInfo = modem.getModemInfo();
SerialMon.print("Modem Info: ");
SerialMon.println(modemInfo);
// Unlock your SIM card with a PIN if needed
if ( GSM_PIN && modem.getSimStatus() != 3 ) {
modem.simUnlock(GSM_PIN);
SerialMon.print("Connecting to APN: ");
SerialMon.print(apn);
if (!modem.gprsConnect(apn, gprsUser, gprsPass)) {
ESP.restart();
else {
SerialMon.println(" OK");
if (modem.isGprsConnected()) {
SerialMon.println("GPRS connected");
// MQTT Broker setup
mqtt.setServer(broker, 8883);
mqtt.setCallback(mqttCallback);
if (!mqtt.connected()) {
SerialMon.println("=== MQTT NOT CONNECTED ===");
// Reconnect every 10 seconds
uint32_t t = millis();
if (t - lastReconnectAttempt > 10000L) {
lastReconnectAttempt = t;
if (mqttConnect()) {
delay(100);
return;
long now = millis();
if (now - lastMsg > 30000) {
lastMsg = now;
Serial.print("Temperature: ");
mqtt.publish(topicTemperature, "HELLO");
mqtt.loop();
