Connecting the "5403-150F Digital Linear Scale" Sensor to an Arduino UNO
I purchased this device: 5403F Digital linear scale with Remote Display - Wenzhou Sanhe Measuring Instrument Co.,LTD.
My intention when buying it was to cut the cable connecting the sensor to the display and instead connect the sensor wires directly to my Arduino Uno. First, I wanted to figure out the relationship between the signal output and the measurement shown on the scale. Then, I planned to write code to convert the received signal into the corresponding measurement in millimeters.
Well, the sensor arrived a few days ago, and since then, I’ve been trying different approaches—but without success. I’ve tested multiple communication protocols, and they all yield the same result: whenever I move the scale, the signal detected in the Serial Monitor doesn’t change, as if the sensor weren’t connected (even though it works perfectly when connected to the original display).
I’m considering buying some adapters to interface between the sensor and the Arduino (such as a USB Host Shield or RS422, for example) to test with those, as I suspect the communication protocol used by this sensor might not be compatible with my Arduino.
However, before deciding whether to purchase them, I thought I’d ask here in the forum to see if anyone could help me with this issue.
That’s it... Thanks for your attention, and I wish you all a good day!
@davifilipe ,
Your other topic on the same subject deleted.
Please do not duplicate your questions as doing so wastes the time and effort of the volunteers trying to help you as they are then answering the same thing in different places.
Please create one topic only for your question and choose the forum category carefully. If you have multiple questions about the same project then please ask your questions in the one topic as the answers to one question provide useful context for the others, and also you won’t have to keep explaining your project repeatedly.
Repeated duplicate posting could result in a temporary or permanent ban from the forum.
Could you take a few moments to Learn How To Use The Forum
Thank you.
You probably took in consideration, that the display unit works at 3V...
So what were they?
