Hi. I’ve been trying to get my GY-521 gyroscope connected to my Arduino UNO R3 this past week and unfortunately I had no luck. Currently I am hooking up the ports as follows:
Vcc - 3.3V
GND - GND
SCL - D5
SDA - D4
ADO - GND
INT - D2
Here is the code I am using
// I2C device class (I2Cdev) demonstration Arduino sketch for MPU6050 class
// 10/7/2011 by Jeff Rowberg <jeff@rowberg.net>
// Updates should (hopefully) always be available at https://github.com/jrowberg/i2cdevlib
// Changelog:
// 2011-10-07 - initial release
I2Cdev device library code is placed under the MIT license
Copyright (c) 2011 Jeff Rowberg
Permission is hereby granted, free of charge, to any person obtaining a copy
of this software and associated documentation files (the "Software"), to deal
in the Software without restriction, including without limitation the rights
to use, copy, modify, merge, publish, distribute, sublicense, and/or sell
copies of the Software, and to permit persons to whom the Software is
furnished to do so, subject to the following conditions:
The above copyright notice and this permission notice shall be included in
all copies or substantial portions of the Software.
THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE
AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM,
OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN
THE SOFTWARE.
// Arduino Wire library is required if I2Cdev I2CDEV_ARDUINO_WIRE implementation
// is used in I2Cdev.h
#include "Wire.h"
// I2Cdev and MPU6050 must be installed as libraries, or else the .cpp/.h files
// for both classes must be in the include path of your project
#include "I2Cdev.h"
#include "MPU6050.h"
// class default I2C address is 0x68
// specific I2C addresses may be passed as a parameter here
// AD0 low = 0x68 (default for InvenSense evaluation board)
// AD0 high = 0x69
MPU6050 accelgyro;
int16_t ax, ay, az;
int16_t gx, gy, gz;
#define LED_PIN 13
bool blinkState = false;
// accelerometer values
int accel_reading;
int accel_corrected;
int accel_offset = 200;
float accel_angle;
float accel_scale = 1; // set to 0.01
// gyro values
int gyro_offset = 151; // 151
int gyro_corrected;
int gyro_reading;
float gyro_rate;
float gyro_scale = 0.02; // 0.02 by default - tweak as required
float gyro_angle;
float loop_time = 0.05; // 50ms loop
float angle = 0.00; // value to hold final calculated gyro angle
// time stamp variables
int last_update;
int cycle_time;
long last_cycle = 0;
// join I2C bus (I2Cdev library doesn't do this automatically)
Wire.begin();
// initialize serial communication
// initialize device
Serial.println("Initializing I2C devices...");
accelgyro.initialize();
// verify connection
Serial.println("Testing device connections...");
Serial.println(accelgyro.testConnection() ? "MPU6050 connection successful" : "MPU6050 connection failed");
// configure Arduino LED for
pinMode(LED_PIN, OUTPUT);
void loop(){
// read raw accel/gyro measurements from device
accelgyro.getMotion6(&ax, &ay, &az, &gx, &gy, &gz);
// accelerometer_X_Axis angle calc
accel_reading = ax;
accel_corrected = accel_reading - accel_offset;
accel_corrected = map(accel_corrected, -16800, 16800, -90, 90);
accel_corrected = constrain(accel_corrected, -90, 90);
accel_angle = (float)(accel_corrected * accel_scale);
Serial.print(accel_angle);
Serial.print("\t");
// gyro_Y_Axis angle calc
gyro_reading = gy;
gyro_corrected = (float)((gyro_reading/131) - gyro_offset); // 131 is sensivity of gyro from data sheet
gyro_rate = (gyro_corrected * gyro_scale) * -loop_time; // loop_time = 0.05 ie 50ms
gyro_angle = angle + gyro_rate;
// print values to serial monitor for checking
Serial.print(gyro_reading);
Serial.print("\t");
Serial.print(gyro_corrected);
Serial.print("\t");
Serial.print(gyro_angle);
Serial.print("\t");
Serial.println(" ");
// blink LED to indicate activity
blinkState = !blinkState;
digitalWrite(LED_PIN, blinkState);
//timestamp
time_stamp();
void time_stamp(){
while ((millis() - last_cycle) < 50){
delay(1);
// once loop cycle reaches 50ms, reset timer value and continue
cycle_time = millis() - last_cycle;
last_cycle = millis();
I got the code from Gyro angle calc code · GitHub
Currently, all that I am getting is the following :
Initializing I2C devices…
Testing device connections…
*-2.00 0 -151 0.15 *
Can someone please help me?
