Connecting to a wireless network
Hello.
I am using an official R3 wifi shield and official R3 mega adk. Using Arduino 1.0.3.
I am having issues connecting to a wireless network, in the same sketch that writes to a SD card using the SDfat library.
This is my code to handle connecting to a network. I have tested this code by inserting the code into a slightly modified WifiWebClientRepeating and it works.
void ConnectToNetwork()
  String SecurityType = "WPA2";
  //String SSIDNAME = "SmartSocket";
  //String PASS = "goodpassword";
  char ssid[SSIDNAME.length() + 1];
  char pass[PASS.length() + 1];
  int index;
  SSIDNAME.toCharArray(ssid, SSIDNAME.length() + 1);
  PASS.toCharArray(pass, PASS.length() + 1);
  Serial.println(ssid);
  Serial.println(pass);
  for ( int i = 0; i < 2; i++ )
    if( status != WL_CONNECTED)
      // WPA2
      if ( SecurityType == "WPA2" )
            Serial.println("in here");
            status = WiFi.begin(ssid,pass);
      // if no security
      if ( SecurityType == "None" )
        status = WiFi.begin(ssid);
      if ( SecurityType == "WEP" )
        status = WiFi.begin(ssid,INDEX.toInt(),pass);
      delay(10000); //waits 10 seconds for connections
  printWifiStatus();
But placing the function in with the rest of my sketch, which can be found below, I am unable to connect to any type of wireless network.
Any suggestion or recommendations? I am completely stumped. Could there be a conflict with SDFat.h, such a pin assignments and dependencies?
I suggest that you read the sticky at the top of the forum. Again, if necessary. Your code is not posted correctly.
You might want to take your snippets to http://snippets-r-us.com. I'm sure that they'll be more help that we can be.
The original post was change to be more in line with the sticky.
This is the entirety of my sketch.
#include <WiFi.h>
#include <SPI.h>
#include <String.h>
#include "RTClib.h"
#include <Wire.h>
#include <stdarg.h>
#include <EmonLib.h>
#include "SdFat.h"
DateTime time;
int currentTime;
RTC_DS1307 RTC;
int keyIndex;
int status = WL_IDLE_STATUS;
char server[] = "yoursmartsocket.com";
WiFiClient client;
int securityType;
String SecurityType;
String SSIDNAME;
String PASS;
String INDEX;
String phpSend;
// Sensor Reading Stuffs
int voltageMains =1;
double current ;
int socketId;
int deviceID = 1337;
int toggleState = 0;
EnergyMonitor emon1;
float currentCalibration = 59.7;
// Establish output and input pins
int voltagePin = A0;
int currentPin = A1;
// file system object
SdFat sd;
// create Serial stream
ArduinoOutStream cout(Serial);
// store error strings in flash to save RAM
#define error(s) sd.errorHalt_P(PSTR(s))
const uint8_t chipSelect = 53;
String toggle;
  pinMode(voltagePin, INPUT);
  pinMode(currentPin, INPUT);
  Serial.println("Test");
  pinMode(53, OUTPUT);
  emon1.current(1, 59.7);
  unsigned long start = millis();
  while (WiFi.status() == WL_NO_SHIELD )
    if ((millis() - start) > 30000)
      Serial.println("WiFi shield not Present");
      while(true);
  cout << pstr("Type any character to start demo \n");
  while (Serial.read() <= 0) {}
  delay(400);  // catch Due reset problem
  if (!sd.begin(chipSelect, SPI_FULL_SPEED))
    sd.initErrorHalt();
  // Read Network Configuration from SD Card
  getConfiguration();
  // Demo
   pinMode(led, OUTPUT);
   current =  emon1.calcIrms(1480);
  // Read Voltage
  ConnectToNetwork();
  voltageMains = 120;
  // Read Current
  Serial.print("Irms is: ");
  Serial.println(current);
  if ( 1 != sendData( current, voltageMains, currentTime, toggleState))
    saveUnSentData( 1 , current, voltageMains, toggleState);
    // Connection worked
    Serial.println("Data is Sent");
   // sendLoggedData();
  toggleState = getToggleState();
  // Toggle the Relay
  Serial.print("Toggle State ");
  Serial.println(toggleState);
// Reads WiFi network configuration from SD card
void getConfiguration() {
  const int line_buffer_size = 64;
  char buffer[line_buffer_size];
  ifstream sdin("Config.TXT");
  int line_number = 0;
  Serial.println("test");
  while (sdin.getline(buffer, line_buffer_size, '\n'))
    ++line_number;
   if ( line_number == 1)
   SecurityType = buffer;
      if ( line_number == 2)
   SSIDNAME = buffer;
      if ( line_number == 3)
   PASS = buffer;
   if ( line_number == 4)
   INDEX = buffer;
 // String SecurityType = "WPA2";
  int index;
      // WPA2
      // if no security
  printWifiStatus();
// This function will send the PHP request
int sendData(int currentScaled, int voltageScaled, int Time, int toggleState)
      String phpStart = "PUT /SmartSocket/arduino_readings?id=";
        phpSend = phpStart;
	//Make connection with server
        if (client.connect(server, 80))
        Serial.println("connected to server to send data");
        char c[4];
        dtostrf(current, 4, 2, c);
        // Send readings to server
        client.println(phpSend + deviceID + "&I=" + c +  "&V=" + (String)voltageScaled +  "&time=" + "2013071318" + (String)random(0, 59) + (String)random(0, 59) + "&state=" + (String)toggleState);
        client.println(F("Host: www.yoursmartsocket.com"));
        client.println(F("Connection: close"));
        client.println();
        Serial.println("Unable to make connection");
        client.flush();
        client.stop();
// This function will send all the logged data to the server
// Then clear the data once it is all sent.
// While data is on card
	// Read Data from card
	// Send Data to server
// Once done overwrite file to clear it
// Check if data is logged on SD CARD
// Send all logged data to server
// clear file once all data is sent
void sendLoggedData()
  char * p;
  char * str;
  int i = 0;
  int time;
  double current;
  int voltage;
  int togglestate;
  ifstream sdin("Unsent.csv");
 // sendData(int currentScaled, int voltageScaled, int Time, int toggleState)
    p = buffer;
    while ( (str = strtok_r(p, ";", &p)) != NULL )
      if ( i == 0 ) // str is time
        time = atoi(str);
        //Serial.print(str);
      else if ( i == 1 ) // str is current
        current = atoi(str);
      //  Serial.print(str);
      else if ( i == 2 ) // str is voltage
        voltage = atoi(str); // voltage is faked see report
    //    Serial.println(str);
      else if ( i == 3 ) // str is togglestate
        togglestate = atoi(str);
      i++;
    i = 0;
   // sendData( current, voltage, time, togglestate);
  // Deletes file then creates a new empty verision
  SdFile myFile;
  myFile.open("Unsent.csv", O_RDWR | O_CREAT | O_AT_END);
  myFile.remove();
  myFile.close();
// This logs data that could not be sent to the server
// Appends to a files
void saveUnSentData(int time, double current, int voltage, int togglestate)
// Stores Data to SD card
  Serial.println("starting");
  char name[] = "Unsent.csv";
    sd.initErrorHalt();
  ofstream sdout(name, ios::out | ios::app);
  if (!sdout)
    error("open failed");
   sdout << time << ";" << current << ";" << voltage << ";" << togglestate <<endl;
  sdout.close();
  if (!sdout)
    error("append data failed");
  Serial.println("done");
// Gets the toggle state from the server
// Sends a http get request to the server
int getToggleState()
  String phpToggleStart = "GET /SmartSocket/arduino_state?id=";
  client.stop();
  // 1 = on 2 = USE scheduler  0 = OFF
   phpSend = phpToggleStart;
  if (client.connect(server, 80) || status == WL_CONNECTED ) // CHange back to &&
        Serial.println("connected to server to get toggle state");
        client.println("GET /SmartSocket/arduino_state?id=1337");
        client.println("Host:www.yoursmartsocket.com");
        client.println("Connection: close");
        client.println();
   delay(50);
      int count = 0;
      char c;
      while(client.connected() && !client.available() && count < 10000 )
        delay(1);
        count++;
      if (client.connected() || client.available())
      { //connected or data available
        c = client.read(); //gets byte from wifi buffer
        Serial.println(c); //prints byte to serial monitor
      client.flush();
      client.stop();
      return (int(c));
  return 0;
// Only for debuging
void printWifiStatus() {
  // print the SSID of the network you're attached to:
  Serial.print("SSID: ");
  Serial.println(WiFi.SSID());
  // print your WiFi shield's IP address:
  IPAddress ip = WiFi.localIP();
  Serial.print("IP Address: ");
  Serial.println(ip);
// Saves data to a csv file and appends to the end
void LogData(int time, double current, int voltage)
    SdFile myFile;
  myFile.open("datalog.csv", O_RDWR | O_CREAT | O_AT_END);
  myFile.close();
  char name[12] = "dataLog.csv";
  if (!sd.begin(10, SPI_FULL_SPEED))
    sd.initErrorHalt();
  if (!sdout)
   sdout << time << "," << current << "," << voltage << endl;
  sdout.close();
  if (!sdout)
Why? Perhaps you should print something useful, like what you read from the file.
Perhaps you could show your serial output.
Perhaps you could consider using Tools + Auto Format, to fix the horrid indenting in your sketch.
Perhaps you could consider spelling GET correctly. This looks like a GET request.
