Connecting to Dragino Yun Shield Arduino Uno: Connection closed by foreign host
I have an Arduino Uno with a Dragino Yun Shield on it. I am trying to run the sample code provided online pasted at the bottom. I upload the sketch and it starts running. I try to look at the serial monitor for the dragino but only the first line of the sketch prints before the line "Connection closed by foreign host" prints and the sketch stops running. Does anyone know what causes this? Is it something specific to the Yun shield setting that I can change?
Here's the code:
#include <Console.h>
String name;
// Initialize Console and wait for port to open:
Bridge.begin();
Console.begin();
// Wait for Console port to connect
while (!Console);
Console.println("Hi, what's your name?");
if (Console.available() > 0) {
char c = Console.read(); // read the next char received
// look for the newline character, this is the last character in the string
if (c == '\n') {
//print text with the name received
Console.print("Hi ");
Console.print(name);
Console.println("! Nice to meet you!");
Console.println();
// Ask again for name and clear the old name
name = ""; // clear the name string
else { // if the buffer is empty Cosole.read() returns -1
name += c; // append the read char from Console to the name string
Hi!
I have the same error.
Can someone help me?
kovecses, you didn't tell which Arduino board you are using.
Uploading a sketch and using the Console via wifi or Ethernet is not working very well.
You can get out of the troubles by using a Arduino Leonardo, and connect its usb to a computer. Upload a sketch via the usb cable and use the serial monitor via the usb cable.
