Connecting to Flash
Im a student of graphic design in Detroit, and i could really use some help.
disclaimer im SUPER new to using Arduino but i have doing a lot of reading.
So i found this project : aaronalai.com/emf-detector <----- real cool
  • I built it and thats all gravy
The problem: I wanna be able to read the EMF data in flash using the NETLab Widget tool kit (analoginput). I THINK I i need to add something to the sketch because none of the data is making it to Flash.
WHAT IM USING:
-Arduino (sketch app)
-NETLabHub
-NETLab Toolkit AS3 Widgets
-Flash CS4
THE CODE IM USING NOW:
int inPin = 5; // analog 5
int val = 0; // where to store info from analog 5
int pin11 = 11; // output of red led
val = analogRead(inPin); // reads in the values from analog 5 and
//assigns them to val
if(val >= 1){
val = constrain(val, 1, 100); // mess with these values
val = map(val, 1, 100, 1, 255); // to change the response distance of the device
analogWrite(pin11, val); // *note also messing with the resistor should change
// the sensitivity
}else{ // analogWrite(pin11, val); just tuns on the led with
// the intensity of the variable val
analogWrite(pin11, 0); // the else statement is just telling the microcontroller
// to turn off the light if there is no EMF detected
Serial.println(val); // use output to aid in calibrating
CHEERS - THANKS FOR YOUR TIME
Cross posting is not recommended. Decide whether this post belongs here or in Interfacing, and delete the other.
You appear to be sending data to the serial port. If Flash isn't seeing it, the problem appears to be on the PC side.
