I'm trying to post temperature data to ThingSpeak. I am able to connect to ThingSpeak on the first attempt, at the end of void setup(), but all attempts after the call to the "getTheTime()" function returns error code 301. If I move "getTheTime()" to before "sendToThingspeak(), I can't connect at all.
I don't understand why the call to "getTheTime()" prevents subsequent connections to ThingSpeak. Any help would be greatly appreciated.
Paul
// V1.6 Test temp sensors
// V1.7 Add timers
// V1.8 Add Thingspeak code
#include <arduino-timer.h>
#include <ezTime.h>
#include <Ethernet.h>
#include <SPI.h>
#include <DallasTemperature.h>
#include <Wire.h>
#include <TFT_FastPin.h>
#include <TFT_ILI9341.h>
#include <User_Setup.h>
#include "secrets.h"
#include "ThingSpeak.h"
#define ONE_WIRE_BUS 28 // Arduino pin for temp sensors
#define trigPin 44 //Sensor Echo pin
#define echoPin 42 //Sensor Trip pin
#define lineColor ILI9341_GREEN
#define textColor ILI9341_RED
#define textColor2 ILI9341_BLUE
#define fillColor ILI9341_WHITE
#define pinkColor 0xb1f8
#define ltYellow 0xb5c7
// Sensor pins
#define sensorPower 32 // Power for level sensor (was 23)
#define sensorPin A8 // Water level sensor pin
#define relayPin 33 // Controls water valve via Elk input (was 25)
#define swPin A5 // Selects display screen
#define trigPin 44 // Distance Sensor Echo pin
#define echoPin 42 // Distance Sensor Trip pin
TFT_ILI9341 tft = TFT_ILI9341();
TFT_ILI9341 tft1 = TFT_ILI9341();
//IPAddress ip(192, 168, 1, 75); // Assign IP address to ethernet shield
//EthernetServer server(80); // Create a server at port 80
OneWire oneWire(ONE_WIRE_BUS);
DallasTemperature sensors(&oneWire);
EthernetClient client;
EthernetClient clientA;
auto timer = timer_create_default(); // create a timer with default settings
Timer<> default_timer; // save as above
// Addresses for pond sensors
/*DeviceAddress tempPh = {0x28, 0xFF, 0x74, 0x14, 0x53, 0x04, 0x00, 0xA8}; // Pumphouse sensor
DeviceAddress temp1ft = {0x28, 0x1e, 0x18, 0x40, 0x19, 0x20, 0x06, 0x2c}; // 1'
DeviceAddress temp2ft = {0x28, 0xab, 0xec, 0x40, 0x19, 0x20, 0x06, 0x79}; // 2'
DeviceAddress temp3ft = {0x28, 0xfe, 0x02, 0x86, 0x19, 0x20, 0x06, 0xf4}; // 3'
DeviceAddress tempPit = {0x28, 0xe4, 0x00, 0x79, 0xa2, 0x16, 0x03, 0xcd}; // Pump pit
//***********Temporary addresses*****************
DeviceAddress tempPh = {0x28, 0xB5, 0x44, 0xE8, 0x05, 0x00, 0x00, 0x64}; // Pumphouse sensor -GREEN
DeviceAddress temp1ft = {0x28, 0xE8, 0x4E, 0xE8, 0x05, 0x00, 0x00, 0xBD}; // 1' - YELLOW
DeviceAddress temp2ft = {0x28, 0x1C, 0xDC, 0xE8, 0x05, 0x00, 0x00, 0x27}; // 2' - PURPLE
DeviceAddress temp3ft = {0x28, 0x0F, 0x5F, 0xE8, 0x05, 0x00, 0x00, 0xA0}; // 3' - RED
DeviceAddress tempPit = {0x28, 0x01, 0x2B, 0xB8, 0x4C, 0x20, 0x01, 0x39}; // Pump pit - Water oroof
String versionNumber = "1.7.2.1"; // Version of this sketch
// Value for storing water level
bool filling = true;
int level = 0;
int avLevel = 0;
int fullLevel = 3000;
int fillLevel = 400;
int fillsToday = 0;
int fillsYesterday = 0;
int d = 1, m = 1, y = 2000, h = 1, mn = 1, s = 1;
int i = 0; // Counter
int a = 0; // Counter
int pass = 0; // Counts passes through screens
int oldDay = 1; // Saves previous date
int oldHour; ///////
int oldMinute; ////// holds old time values
int oldSecond; //////
unsigned long myChannelNumber = SECRET_CH_ID;
const char * myWriteAPIKey = SECRET_WRITE_APIKEY;
//String amPM = " ";
String pondStatus = "Waiting ";
const char* tsserver = "api.thingspeak.com";
unsigned long channelNumber = deleted; // "Greenhouse" channel
const char* writeKey = "deleted"; // Greenhouse write key
float TempPh = 70, Temp1ft = 71, Temp2ft = 72, Temp3ft = 73, TempPit = 74;
byte mac[] = {0xDE, 0xA0, 0x5E, 0x23, 0x8E, 0x4D};
int percent;
float duration, distance;
Timezone PST;
PST.setPosix("UTC+7:00");
PST.setDefault();
tft.begin();
//Ethernet.begin(mac, ip); // Initialize Ethernet shield
sensors.begin();
tft.setRotation(3);
tft.setTextSize(3);
tft.setTextColor(ILI9341_BLACK);
tft.fillScreen(lineColor);
tft.setCursor(100, 20);
tft.print("Sketch");
tft.setCursor(20, 60);
tft.print("Pond_Temps ");
tft.print(versionNumber); //Current version of this sketch
// Enter a MAC address for your controller below. (Or use address below, just make sure it's unique on your network)
// Newer Ethernet shields have a MAC address printed on a sticker on the shield
#define MAC_ADDRESS { 0xBA, 0xAA, 0xAD, 0xDC, 0xFF, 0xEB }
#define EZTIME_ETHERNET
Serial.print(F("Ethernet connection ... "));
byte mac [] = MAC_ADDRESS;
if (Ethernet.begin(mac) == 0) {
Serial.println(F("failed. (Reset to retry.)"));
while (true) {
}; // Hang
Serial.print(F("got DHCP IP: "));
Serial.println(Ethernet.localIP());
delay(1000); // give the Ethernet shield a second to initialize:
waitForSync(); // Wait for ezTime to get its time synchronized
Serial.println("UTC: " + UTC.dateTime());
Serial.println("PST: " + PST.dateTime());
Serial.println(dateTime());
pinMode(sensorPin, INPUT);
pinMode(sensorPower, OUTPUT);
pinMode(relayPin, OUTPUT);
pinMode(trigPin, OUTPUT);
pinMode(echoPin, INPUT);
pinMode(swPin, INPUT);
digitalWrite(sensorPower, LOW); // Set to LOW so no power flows through the sensor
Serial.println(PST.dateTime(COOKIE));
Serial.println(PST.dateTime("l, F j, Y g:i:s"));
sensors.setResolution(12);
ThingSpeak.begin(clientA);
timer.every(1000, readWaterLevel); //Read water level once a second
timer.every(12000, getTemps); //Read the temp sensors every 12 seconds
timer.every(60000, sendToThingspeak); // Send to Thingspeak every minute
timer.every(120000, getTheTime); // Get UTC time every hour (3600000 milliseconds)
tft.setTextColor(ILI9341_BLACK, ILI9341_GREEN);
getTemps();
sendToThingspeak();
getTheTime();
timer.tick(); // tick the timer
tft.setCursor(35, 205);
tft.print(pondStatus);
void getTemps() {
i++;
sensors.requestTemperatures();
Serial.println("Request Temps");
Serial.print("i = ");
Serial.println(i);
switch (i) {
case 1:
Serial.println("Case 1");
TempPh = sensors.getTempF(tempPh);
case 2:
Serial.println("Case 2");
Temp1ft = sensors.getTempF(temp1ft);
case 3:
Serial.println("Case 3");
Temp2ft = sensors.getTempF(temp2ft);
case 4:
Serial.println("Case 4");
Temp3ft = sensors.getTempF(temp3ft);
case 5:
Serial.println("Case 5");
TempPit = sensors.getTempF(tempPit);
i = 0;
Serial.println(TempPh);
Serial.println(Temp1ft);
Serial.println(Temp2ft);
Serial.println(Temp3ft);
Serial.println(TempPit);
return true;
bool readWaterLevel(void *) {
a++;
//Serial.println(" READING WATER LEVEL");
digitalWrite(sensorPower, HIGH); // Turn level sensor ON
level = analogRead(sensorPin); // Read sensor
digitalWrite(sensorPower, LOW); // Turn level sensor OFF
// Serial.println(level);
avLevel = (avLevel + level);
if (a == 3) {
a = 0;
avLevel = (avLevel / 3);
if (avLevel < 401) {
// Serial.print(avLevel);
// Serial.print("*******************");
digitalWrite(relayPin, LOW);
// Serial.println("Wire is broken");
pondStatus = "WIRE IS BROKEN ";
else if (400 < avLevel && avLevel < 540) {
digitalWrite(relayPin, HIGH);
pondStatus = "POND IS FILLING";
if (filling == true) {
fillsToday = fillsToday + 1;
filling = false;
else {
pondStatus = " POND IS FULL ";
filling = true;
avLevel = 0;
void sendToThingspeak() {
Ethernet.begin(mac);
ThingSpeak.setField(1, TempPh);
ThingSpeak.setField(2, Temp1ft);
ThingSpeak.setField(3, Temp2ft);
ThingSpeak.setField(5, Temp3ft);
ThingSpeak.setField(6, TempPit);
// write to the ThingSpeak channel
int x = ThingSpeak.writeFields(myChannelNumber, myWriteAPIKey);
if (x == 200) {
Serial.println("Channel update successful.");
else {
Serial.println("Problem updating channel. HTTP error code " + String(x) + PST.dateTime());
void getTheTime() {
waitForSync();
Serial.println("5 Second delay");
tft.setCursor(85, 100);
tft.print("Reset at");
tft.setCursor(10, 130);
tft.print(PST.dateTime("F j, Y"));
tft.setCursor(80, 165);
tft.print(PST.dateTime("h:i:s"));
