Im currently doing a project with 12 photocells, which will send analog input to MaxMsp. Im using two arduinos- and it is possible to read from both boards at the same time, BUT.. My problem is that the connection seems to be very unstable when I read from both at the same time. I need som help to figure out how I can get stable readings from two arduinos
I have two arduino uno boards- each have 6 photocells connected via analog input. Both boards are connected with USB.
I am using MaxMsp to read the values. On each board I uploaded the arduino script for ARDUINO2MAX. I alos made sure each board is connedted to a specific serial port.
I can get values from both boards into MaxMsp, thats not a problem. The ISSUE is that the values gets unstable when I use two arduino boards at the same time. It works fine if I only use one board at the time.
bjoerndamalrsen:
Is it possible the PC program is closing a serial port when it switches to read the other port?
It should keep both ports open all the time.
