Connecting two arduinos to the arduino software ?
Hello,
(I am new to this forum)
I have two arduino's connected to my mac with two usb cables.
I want one sketch to connect to the first arduino, and another to connect to the second one. And I would like to open a serial monitor for each arduino (simultaneously). Is this possible ?
Whenever I select a usb interface, it connects both sketch to this interface (instead of only one)
Whenever I open a serial monitor, it automatically closes the existing serial monitor. It seems impossible to open two serial monitors.
Is the arduino software meant to be used with only one arduino at a time ?
Thank you for any help.
paul
No itis not possible.
To do this you have to use another terminal program so it can open a separate USB port.
Thank you for replying so fast!
paulcobbaut:
Hello,
paul
Hi Paul! Welcome!
I do this all the time ;-). It isn't possible from when running a single Arduino IDE but it is not a problem to start several Arduino IDE's and connect them to different COM ports. I work mostly on Linux and need to test network protocols etc. Then this comes in handy.
Cheers!
