Connecting two HM-10 BLE modules together manually by AT+CON[slave mac] command
Hi guys, I am trying to connect two Nano Arduinos together by HM-10 Bluetooth BLE Modules,
(Master and Slave HM-10 BLE modules are connected to different Nano Arduinos)
I could connect them in the Automatic mode;
when “AT+IMME0” and “AT+ROLE1” for the Master,
and “AT+IMME0” and “AT+ROLE0” for the Slave.
But when I make it manual, I am not able to connect them by “AT+CONxxxxxxxxxxxx”,
which is written in the master code to connect to a specific slave mac address “xxxxxxxxxxxx”.
Actually, I could connect them by using “AT+START”, but by using this command I am not able to specify the mac of the wanted slave to connect, so it could be connected to another one (if there was in the area!!).
How can I solve this problem !!
My HM-10 BLEs version is “HMSoft V609”
My codes are below:
Master Code:
#include <SoftwareSerial.h>
#define Serial_Baud 9600
#define HM10_Baud 9600
#define RX 2
#define TX 3
SoftwareSerial HM10(RX, TX); //2, 3
char c = ' ';
boolean NL = true;
  Serial.begin(Serial_Baud);
  Serial.println("Master Bluetooth");
  Serial.println(" ");
  HM10.begin(HM10_Baud);
  if (HM10.available()) {
    c = HM10.read();
    Serial.write(c);
  if (Serial.available()) {
    c = Serial.read();
    // Do not send line end characters to the HM-10
    if (c != 10 && c != 13) {
      HM10.write(c);
    // If there is a new line print the ">" character.
    if (NL) {
      Serial.print("\r\n>");
      NL = false;
    // Echo the user input to the main window.
    Serial.write(c);
    if (c == 10)  {
      NL = true;
Slave Code:
#define RX 2
#define TX 3
  Serial.println("Slave Bluetooth");
    Serial.write(HM10.read());
    HM10.write(Serial.read());
My Problem has been solved.
I have upgraded the version of “HM-10” firmware from “v609” to “v707”
by flashing it by the programs bellow (in the attachments) using FTDI module.
Muhammed Genco
HMSoft-10-2541-V707.zip (778 KB)
