Connecting two IR receivers
Hello I was watching this tutorial for these type of IR sensors:
https://learn.sparkfun.com/tutorials/ir-control-kit-hookup-guide
https://learn.sparkfun.com/tutorials/ir-communication
Now, I am trying to connect two IR receivers and I have the following code, but it does only detect from one IR detector, can anyone please provide me with clue on why this only read from one sensor? It only reads from pin 11. I would very much appreciate your help, thank you */
#include <IRremote.h> // Include the IRremote library
const int buzzPin = 6;
int RECV_PIN_1 = 11;
int RECV_PIN_2 = 10;
/* Initialize the irrecv part of the IRremote  library */
IRrecv irrecv1(RECV_PIN_1);
IRrecv irrecv2(RECV_PIN_2);
decode_results results1; // This will store our IR received codes
decode_results results2; // This will store our IR received codes
  Serial.begin(9600); // Use serial to debug.
  irrecv1.enableIRIn(); // Start the receiver
  irrecv2.enableIRIn(); // Start the receiver
  pinMode(13, OUTPUT); //declare pin 13 as an output
  digitalWrite(13, HIGH);   // Turn on the LED
  delay(50);              // Wait for one second
  digitalWrite(13, LOW);    // Turn off the LED
  if (irrecv1.decode(&results1))
    // read the RX'd IR into a 16-bit variable:
    uint16_t resultCode1 = (results1.value & 0xFFFF);
    switch (resultCode1)
      /*case 1:
        case 2:
        case 3:
      default:
        Serial.print("IR detected_1: ");
        Serial.println(results1.value, HEX);
        buzz(50);
    irrecv1.resume(); // Receive the next value
  if (irrecv2.decode(&results2))
    uint16_t resultCode2 = (results2.value & 0xFFFF);
    switch (resultCode2)
      /*case 1:
        case 2:
        case 3:
        default:
        Serial.print("IR detected_2: ");
        Serial.println(results2.value, HEX);
        buzz(50);
    irrecv2.resume(); // Receive the next value
  } //endloop
 void buzz(byte time)
    analogWrite(buzzPin,170);
    delay(time);
    analogWrite(buzzPin,0);
    delay(time);
What happens when you switch the detectors around in hardware, in software
Stop using delay() in your sketches.
Why two receivers.
Different frequencies, different locations?
If they are used for a wider view...
3-pin receivers have open collector outputs with weak pull up resistors, and can be connected in parallel.
Leo..
Hello LarryD, Thanks for your help:
What happens when I switch the detectors around in hardware, in software?
The only pin that reads info from the IR receiver signal is the pin that is listed last in the code above the setup loop.
Why do you recommend to stop using delay()? What do you suggest to use instead to accomplish the same as a delay()?
Hello Wawa, Thanks for your help too.
My ultimate goal is to try using this IR receivers as proximity sensors.
I have not tried two detectors at the same time.
delay() stops all sketch progression for that time, use millis() BWD BlinkWithoutDelay
See:
http://playground.arduino.cc/Code/AvoidDelay
Robin2s discussion:
https://forum.arduino.cc/index.php?topic=223286.0
Example of doing 3 things at the same time
//Simple BWD BlinkWithoutDelay examples
//Timer variables used
unsigned long currentMillis;
unsigned long pin13Millis;
unsigned long pin12Millis;
unsigned long SwitchMillis;
//if these are not changed in the sketch, they can be const
unsigned long debounceMillis = 50UL;  //50ms
unsigned long ledOnTime      = 500UL; //500ms seconds
byte lastSwitchState = HIGH;
byte buttonState     = HIGH;
//enable/disable flags
boolean flag13 = true;
boolean flag12 = false;
const byte Switch = 2; //pushed = LOW
  digitalWrite(13,LOW);
  digitalWrite(12,LOW);
  pinMode(12, OUTPUT);
  pinMode(Switch, INPUT_PULLUP); //pushed = LOW
} //  >>>>>>>>>>>>>> E N D  O F  s e t u p ( ) <<<<<<<<<<<<<<<<<
  //save the current time
  currentMillis = millis();
  //Heartbeat LED
  //Toggle LED on and off. Helps show if there is blocking code
  if (flag13 == true && currentMillis - pin13Millis >= ledOnTime)
    pin13Millis = millis();            //re-initialize Timer
    digitalWrite(13,!digitalRead(13)); //toggle LED condition
  if (flag12 == true && currentMillis - pin12Millis >= 5*1000UL)
    //Turn off pin 12
    digitalWrite(12,LOW); //Turn off LED
    flag12 = false;       //disable timing
  //is it time to check the switches?
  if (currentMillis - SwitchMillis >= debounceMillis)
    //code here runs every debounceMillis ms
    SwitchMillis = millis(); //re-initilize Timer
    //go and check the switches
    checkSwitches();
  //put other non-blocking stuff here
} //  >>>>>>>>>>>>>> E N D  O F  l o o p ( ) <<<<<<<<<<<<<<<<<
//                      F U N C T I O N S
//****************** c h e c k S w i t c h e s ( ) *********************
//switches are checked every debounceValue milli seconds
//no minimum switch press time is validated with this code (i.e. No glitch filter)
void checkSwitches()
  //re-usable for all the switches
  boolean thisState;
  //check if this switch has changed state
  thisState = digitalRead(Switch);
  if (thisState != lastSwitchState)
    //update the switch state
    lastSwitchState = thisState;
    //this switch position has changed so do some stuff
    //"LOW condition code"
    //has switch gone from HIGH to LOW?
    if(thisState == LOW)
      //Do some LOW switch stuff here
      flag12 = true;          //allow timing
      digitalWrite(12, HIGH); //turn on LED
      pin12Millis = millis(); //initialize Timer
  } //END of Switch code
  // similar code for other switches goes here
} //END of checkSwitches()
//                      E N D  O F  C O D E
edcalles:
You didn't post a link to the sensors.
If they are common 3-pin remote control sensors, then that's not possible.
Leo..
Thank you guys for your feedback,
That definitely made me think about other things to implement.
I appreciate your help, Thank you.
