Connecting two Ultrasonic with servo motor with different angles and leds (red,green))
Dear programmers,
It's my first time posting . I'm a beginner with Arduino and following Mr. Paul McWhorter's online courses.
I'm building a smart home for my cat , I used an Internal and External Ultrasonic sensors to control the direction of the door.
Please ,I want you to clear for me what's wrong/modify in my code to make the process as stable on demand as a single ultrasonic does.
so ,the servo motor keeps working with the 3 angles without stopping.
I do a good job with the individual components coding not with multiple .
best regards
#include<Servo.h>
int servoPin=6;
int redPin=8;
int greenPin=9;
int redPin01=10;
int greenPin01=11;
Servo myServo;
int trigPin=2; //Sensor Trip pin connected to Arduino pin 2
int echoPin=3;  //Sensor Echo pin connected to Arduino pin 3
int trigPin01=4; //Sensor Trip pin connected to Arduino pin 4
int echoPin01=5;  //Sensor Echo pin connected to Arduino pin 5
float pingTime;  //time for ping to travel from sensor to target and return
float pingTime01;  //time for ping to travel from sensor to target and return
float targetDistance; //Distance to Target in centimeter
float targetDistance01; //Distance to Target in centimeter
float speedOfSound=776.5; //Speed of sound in miles per hour when temp is 77 degrees.
float speedOfSound01=776.5; //Speed of sound in miles per hour when temp is 77 degrees.
pinMode(trigPin,OUTPUT);
pinMode(trigPin01,OUTPUT);
pinMode(echoPin,INPUT);
pinMode(echoPin01,INPUT);
pinMode(redPin,OUTPUT);
pinMode(redPin01,OUTPUT);
pinMode(greenPin,OUTPUT);
pinMode(greenPin01,OUTPUT);
myServo.attach(servoPin);
  myServo.write(90);
   digitalWrite(trigPin, LOW); //
   digitalWrite(trigPin01, LOW); //
   digitalWrite(redPin,HIGH);
   digitalWrite(greenPin,LOW);
   digitalWrite(redPin01,HIGH);
   digitalWrite(greenPin01,LOW);
   delay(3000);
  if(targetDistance <= 21){
    myServo.write(180);
   digitalWrite(trigPin, HIGH); //Set trigPin high
   digitalWrite(trigPin01, LOW); //Set trigPin highdigitalWrite(redPin,LOW);   digitalWrite(greenPin,HIGH);
   delay(3000);
if(targetDistance01 <= 21){
    myServo.write(0);
   digitalWrite(trigPin, LOW); //Set trigPin high
   digitalWrite(trigPin01, HIGH); //Set trigPin highdigitalWrite(redPin,LOW);   digitalWrite(greenPin,HIGH);
   digitalWrite(redPin01,LOW);
   digitalWrite(greenPin01,HIGH);
     delay(3000);
 if (targetDistance>=21){
     myServo.write(90);
   digitalWrite(trigPin, LOW); //ping has now been sent
   digitalWrite(trigPin01, LOW); //ping has now been sent
   if (targetDistance01>=21){
     myServo.write(90);
   digitalWrite(trigPin01, LOW); //ping01 has now been sent
  pingTime = pulseIn(echoPin, HIGH);  //pingTime is presented in microceconds
  pingTime01 = pulseIn(echoPin01, HIGH);  //pingTime01 is presented in microceconds
  pingTime=pingTime/1000000; //convert pingTime to seconds by dividing by 1000000 (microseconds in a second)
  pingTime=pingTime/3600; //convert pingtime to hourse by dividing by 3600 (seconds in an hour)
   pingTime01=pingTime01 /1000000; //convert pingTime01 to seconds by dividing by 1000000 (microseconds in a second)
   pingTime01=pingTime01 /3600; //convert pingtime01 to hourse by dividing by 3600 (seconds in an hour)
  targetDistance= speedOfSound * pingTime;  //This will be in miles, since speed of sound was miles per hour
  targetDistance=targetDistance/2; //Remember ping travels to target and back from target, so you must divide by 2 for actual target distance.
  targetDistance= targetDistance*160934;    //Convert miles to cm by multipling by 160934 (cm per mile)
  targetDistance01= speedOfSound01  * pingTime01;  //This will be in miles, since speed of sound was miles per hour
  targetDistance01=targetDistance01 /2; //Remember ping travels to target and back from target, so you must divide by 2 for actual target distance.
  targetDistance01= targetDistance01 *160934;    //Convert miles to cm by multipling by 160934 (cm per mile)
  delay(250); //pause to let things settle
How is this in the LEDs and Multiplexing category?
That's what all Arduino tutorials suck at.
A brief analysis of your code can identify some problems:
  1. Open braces on line 100 and close on line 125, for no reason.
  2. Following your code:
    Entering the loop moves the servo to 90;
    testing::
    targetDistance <= 21 if servo moves to 180;
    targetDistance >= 21 if servo moves to 90;
    targetDistance01 <= 21 if servo moves to 0;
    targetDistance01 >= 21 if servo moves to 90;
2.A. If the targetDistance is = 21 it goes to 180 and then to 90;
then it goes to 90, because when it goes back to the beginning of the loop it goes back to 90.
2.B. If targetDistance01 is = 21 it goes to 0 and then to 90;
2.C. If targetDistance is < 21 it goes to 180 and then to 0;
Your servo always goes back to 90 in the loop() loop.
and so on.
You need to review your code's action logic.
