Connecting two wires to the same pin
Hello!
I'm currently working on esp32 cam door lock.
The esp32 camera is both connected to FTDI and relay module. My problem is how connect two wires to the same pin of the esp32 camera on a breadboard?
look at this image, I need to connect both the FTDI and the relay module to the 5v of the esp32 camera. How can I do that?
4
Make a Y/V cable.
Do you think soldering 3 wires together (T shape) will do the same job?
Do your soldering neatly and use heat shrink.
What sort of breadboard?
If like in post #2, you just used the protoboard as a distribution point.
Tom... :grinning: :+1: :coffee: :australia:
Other post/duplicate DELETED
Please do NOT cross post / duplicate as it wastes peoples time and efforts to have more than one post for a single topic.
Continued cross posting could result in a time out from the forum.
Could you also take a few moments to Learn How To Use The Forum.
Other general help and troubleshooting advice can be found here.
