And one end comes with a positive and negative wire attached. I have stripped about an inch from both ends revealing some VERY small stranded wires, and I was wondering how I should go about connecting them into a breadboard because they are very flimsy.
Get a little piece of solid wire and solder it onto the end of the stranded to make a little pin for it. When I trim the leads off of resistors I tend to save the little pieces for just such an occasion.
Cut the lead off a resistor or header pin and wrap the stranded wire around it as tight as possible and cover with tape or heat shrink tubing. It won’t be 100% reliable, but it will work on a breadboard.
The cheapest soldering irons are really cheap. They aren’t much good at much, but they are fine for this kind of thing.
I use a wire ferrule like this (16 ga): https://www.digikey.com/product-detail/en/american-electrical-inc/121210150/288-1096-ND/266462
Wrap the fine stranded wire tightly around a piece of bare 22 ga solid or DuPont header post with the plastic spacer removed, slip the ferrule over the wound part leaving 6 - 8 mm exposed to go in the breadboard and crimp. If you don't have a crimping tool you can use a (preferably dull) pair of side cutters (GENTLY, just crimp, don't cut) then solder if you have the equipment, but it works OK without.
Qdeathstar:
The aluminum wire is probably actually copper clad aluminum so it is fine, especially for the small current draw associated with an led strip.
sterretje:
Define small. 2A is not small in my vocabulary
Agreed. 2A is pushing it for a breadboard. Try to spread the current load over 2 breadboard strips if you can find a way to do that, including the ground/0V. Or maybe just limit the pwm values to max 128, assuming you are using pwm.
