Hi there,I got two Arduino NG USB Boards here. I am trying to get a connection via serproxy on OS X. Therefore I got two setups, changing the usb devices (A3000Xcw for the first boad, and A1015BL for the second) in the serproxy.cfg.One connection works flawless. but the second board just doesn't connect using serproxy.Wenn checking the dev folder it shows that there is a problem with the second boards name!the name which shows up in the tool menu of arduino is " A1015BL". But when I check the "dev" folder the device is called " A10?15BL".Is there a way to change the name of the board? Or can it be that the is a character which is not recognized?best regards,dan
My friend Patrick checked my board, and it seems like the boards serial number uses a secret character, which isn't shown in Arduinos tool menu!
Maybe this is a Arduino bug or a mistake of the manufacturer of the board. I bought the boards from PCB Europe.
I have the same problem my board does not connect and my port in arduino is cu.usbserial-A1015Ci but when I enter into terminal to see the devices connected I see cu.usbserial-A10?15Ci. From other programs I got a different character instead of the question mark...
Hmm, sounds like some sort of bug with the FTDI drivers (or just strange behavior). Try typing this at the Terminal when the Arduino board is connected to find out what that character is (and post the results here for the rest of us, please):
the hex "10" stands for char "DLE" (Date Link Escape), don't know what char on my kexboard this should be :-/
We fixed it here by opening the arduino config file with a editor (subethaedit) and telling the editor to show the hidden characters. Looked in the config file for the last board connected and copyied it to the serproxy config file.
Great to hear you have it working. I downloaded subethaedit and it is showing also hidden characters. Can you please give me the path of the configuration file that shows the last board connected ?
you could try /dev/tty.usbserial-A10\02015Ci in your case
or use subethaedit to open usr/library/arduino/preferences.txt and look for "serial.port".
let it show you the hidden characters. copy the whole string to the serproxy.cfg.
