Connecting Xbees with Arduinos
I have Arduino Uno and Arduino nano, Both connected to Xbees. I have few questions.
  1. I want to send data from Nano to Uno Via Xbees. I have make Xbee of nano as End device. And I have configured the Xbee of Uno as Cordinator.
Do I have to add libraries for sending data between these 2 devices? Here is my code for End device.
Serial.write(0x03);
Serial.write(0x03);
Serial.write(0x03);
Here is my code for cordinator/.
int incoming=0;
if (Serial.available() > 0) {
// read the incoming byte:
incoming = Serial.read();
  1. I connect both Arduinos to my PC. Could that make problems?
  2. I have used following video for my connectionshttps://www.youtube.com/watch?v=cf3RLBg4t5s&t=124s
which tells to connect Rx to Rx and Tx to Tx of Arduino and Xbees respectively. Whereas I saw otherway around in some cases. But for me this works well as the XCTU only detects those connections shown in video.
No.
That code is not giving the XBee time to send the data and get an acknowledgement.
No.
You seem to have forgotten to tell us what problem(s) you are having.
The problem is the code is not getting uploaded to the device sometimes!! It uploads only when I do not bypass the Arduino Bootloader by sorting the pins RST and GND. Also, I keep the X-CTU open. Which gives me error that COM 5 is already in use. So I have to close that.
I dont see the data on Receiver side!! I open Serial monitor but there is no data.
Serial.write(0x03);
Serial.write(0x03);
Serial.write(0x03);
Adding on to my previous comments.
I am receiving data now, It is a Garbage value. Also when I power of the sending Arduino+Bee the serial monitor of receiver is showing some data Why so?
Also, for Finding the Xbees on XCTU I need to connect the (RX-Xbee to RX-Arduino)!! and not Tx to Rx!! What should be the reason? When I do it other way round the Xbees dont show up!!
I get the following error also when I do upload.
Binary sketch size: 2,000 bytes (of a 30,720 byte maximum)
avrdude: stk500_getsync(): not in sync: resp=0x00
but it tells me "Done Uploading". What does it mean? It got uploaded or not uploaded Or with errors?
"Done Uploading" in this case means the IDE is done with it's attempts to transfer the .hex file into your card.
The not in sync response means the file didn't transfer.
thank you, BTW I found the problem is with hardware connection. When I disconnect the RX pin to Xbee it uploads well. What can I do to avoid this problem?
Easy, stop using the hardware serial port for XBee comms and use softwareserial.h instead.
hum… I changed a programs but nothing seems to work with Arduinos… It works in XCTU.
Here are the programs…
#include <SoftwareSerial.h>
SoftwareSerial mySerial(10, 11); // RX, TX
while(1)
mySerial.write(0x03);
Serial.print(‘D’);
mySerial.print(‘F’);
int incoming;
while(!Serial);{
if (Serial.available()>0)
incoming= Serial.read();
Serial.print(“I got it”);
mySerial.print(“hello all”);
incoming= mySerial.read();
You need to add
mySerial.begin(baudrate) to setup() or else the Software Serial will not initialize
Hum, you mean everything else in the program is OK?
It is still not working let me post my updated code…
Transmitter code
mySerial.begin(9600);
while(1)
Serial.print(‘D’);
Serial.write(0x31);
And the Receiver code
int incoming=0;
Serial.print(incoming);
mySerial.print(incoming);
What are your Xbee's baud rate set to?
Get rid of those delay() calls in the receiver code.
  while(1)
  Serial.print('D');
  Serial.write(0x31);
  mySerial.print('F');
Do you really no understand that loop() already loops?
If there is data on the hardware serial port that has not been read, it is NOT OK to read from the XBee.
