Connection between Arduino and BT Module (linvor)
Hi all,
I'm tackling my first bluetooth setup, and I've been able to get pretty far, but now i'm stumped.
First, here are the configurations.
Windows 8
Arduino UNO on COM 6 (USB - 9600 baud)
Bluetooth (linvor) 115200 baud device (4 prong)
COM 7: 115200/8/None/1/None (FIFO on, RCV/TRANS buffers are maxed out in config)
COM 8: 115200/8/None/1/None (FIFO on, RCV/TRANS buffers are maxed out in config)
Pin Setup:
BT.RXD - Pin 6
BT.TXD - Pin 7
BT.VCC - 5v
BT.GND - GND
Sketch on the Arduino: (I pulled this off of google somewhere to help test the BT communications. I'm too n00b to know if this is accurate)
/* Include the software serial port library */
#include <SoftwareSerial.h>
/* DIO used to communicate with the Bluetooth module's TXD pin */
#define BT_SERIAL_TX_DIO 7
/* DIO used to communicate with the Bluetooth module's RXD pin */
#define BT_SERIAL_RX_DIO 6
/* Initialise the software serial port */
SoftwareSerial BluetoothSerial(BT_SERIAL_TX_DIO, BT_SERIAL_RX_DIO);
  /* Set the baud rate for the hardware serial port */
  /* Set the baud rate for the software serial port */
  BluetoothSerial.begin(115200);
/* Main loop that will pass any data to and from the Bluetooth mode to the
   host PC */
  /* If data is available from the Bluetooth module then pass it on to the
     hardware serial port. */
  if (BluetoothSerial.available())
    Serial.write(BluetoothSerial.read());
   /* If data is available from the hardware serial port then pass it on
      to the Bluetooth module. */
  if (Serial.available())
    BluetoothSerial.write(Serial.read());
I'm using RealTerm to test bluetooth communications and to send sample data back and forth.
on RealTerm, I have port 7 open @ 115200/8/None/1/None and it will connect fine to bluetooth.
So, when I send data from the Arduino Serial Monitor (set to 115200) It shows up on the RealTerm window.
When I send data from RealTerm it shows up as Chinese Hieroglyphics in the Serial Monitor.
Here is where I need help. I don't know if it is communicating correctly. When I send data via BT, it gets garbled. When I send it over USB, it's fine. So, am I missing something, is this the right software to be using? Maybe my sketch is way off. I've gotten to a point where I understand the basics, but I need to get some really good direction.
Appreciate any guidance you can give me. Attached is a screenshot explaining what I am ending up with.
~Doc
