Connection between arduino and ethernet shiled only prints "connection failed
I'm using an ethernet shield for Arduino to connect it to a socket server (different computer) so that I can receive messages from it to activate some routine. Here is my code (ino file has also been uploaded):
#include <SPI.h> // needed for Arduino versions later than 0018
#include <Ethernet.h>
#include <SoftwareSerial.h>
SoftwareSerial RFID(2, 3); // RX and TX
// Enter a MAC address and IP address for your controller below.
// The IP address will be dependent on your local network:
byte mac[] = {0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
IPAddress ip(192, 168, 1, 177);
IPAddress gateway(192,168,1, 1);
IPAddress subnet(255, 255, 255, 0);
IPAddress serverIP(192,168,1,3);
int serverPort=8887;
EthernetClient client;
int msg;
char newtag[14] = { 0,0,0,0,0,0,0,0,0,0,0,0,0,0}; // rfid tag value
//functions
void readTags()
if (RFID.available() > 0)
// read tag numbers
delay(100); // needed to allow time for the data to come in from the serial buffer.
for (int z = 0 ; z < 14 ; z++) // read the rest of the tag
int data1 = RFID.read();
newtag[z] = data1;
RFID.flush(); // stops multiple reads
// start the Ethernet and UDP:
Ethernet.begin(mac,ip);
RFID.begin(9600); // start serial to RFID reader
if (client.connect(serverIP, serverPort))
Serial.println("server Conected");//report it to the Serial
Serial.println("reading rfid tag:");
readTags();
Serial.print("rfid tag: ");
Serial.println(newtag);
client.print(newtag);//send the message
else {
// if you didn't get a connection to the server:
Serial.println("connection failed");
client.stop();
Now, the problem is when I run the code, it just prints "connection failed" forever. How can I do this? Thanks!
sketch_nov09a.ino (1.48 KB)
It most certainly is NOT! Learn to read data when it is available, without needing to wait for it.
Are you running a service on 192,168,1,3 that is listening for clients to connect to port 8887?
What service is it? Most people are running httpd, listening to port 80. That service expects clients to make GET requests, identifying which script they want to run. Just printing stuff to the server is most unusual.
Not reading the server response is going to cause you problems.
PaulS:
Hope you don't shout at me but I am sorry I really didn't get your point...I am a newbie in this. Sorry about that
