connection between Arduino Ethernet Shield and dc Motor
Hello everyone........
I am actually new with Arduino. I am trying to control DC Motr with Android Application.
I have connected dc motor with Ethernet shield with GND and pin 9 but when I switch on using app it dose not work. but when I change it with LED it works for me.
this is my code
#include <SPI.h>
#include <Ethernet.h>
#include<Servo.h>
#define htons(x) ( (((x)&0xFF)<<8) | (((x)>>8)&0xFF) )
//new #include<Servo.h>
// new Servo myServo
Servo myServo;
//light pin9
//fan pi22
//garage door pin24
// Set the MAC address
int pos=0;
byte mac[] = {
  0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED
//78-31-C1-C5-3D-C8
// Set the IP address
IPAddress ip(192, 168, 1, 14);
// Start a server at port 80 (http)
EthernetServer server(80);
  // Open serial communications
  // start the Ethernet connection and the server
  Ethernet.begin(mac, ip);
  server.begin();
  // Pin 22 - 24 output (leds)
  pinMode(9, OUTPUT);
  pinMode(5, OUTPUT);
  myServo.attach(30);
  //new myServo.attach(24);
  // Check if client connected
  if (client) { // If there is a client...
    boolean currentLineIsBlank = true;
    String buffer = ""; // A buffer for the GET request
    while (client.connected()) {
      if (client.available()) {
        char c = client.read();// Read the data of the client
        buffer += c; // Store the data in a buffer
        if (c == '\n' && currentLineIsBlank) {// if 2x new line ==> Request ended
          // send a standard http response header
          client.println("Content-Type: text/html");
          client.println("Connection: close");
          client.println(); // Blank line ==> end response
        if (c == '\n') { // if New line
          buffer = "";  // Clear buffer
        else if (c == '\r') { // If cariage return...
         if(buffer.indexOf("GET /?led2=1")>=0) { // If led2 = 1
            digitalWrite(9, HIGH); // led 2 > on
           if(buffer.indexOf("GET /?led2=0")>=0) { // If led2 = 0
            digitalWrite(9, LOW); // led 2 > off
            if(buffer.indexOf("GET /?led3=1")>=0) { // If led3 = 1 for light
            digitalWrite(5, HIGH); // led 3 > on
          if(buffer.indexOf("GET /?led3=0")>=0) { // If led3 = 0
            digitalWrite(5, LOW); // led 3 > off
            //new
      if (buffer.indexOf("GET /?led1=1")>=0) {
            for (pos = 0; pos < 105; pos += 3) // goes from 0 degrees to 180 degrees
            { // in steps of 1 degree
              myServo.write(pos);              // tell servo to go to position in variable 'pos'
              delay(15);                       // waits 15ms for the servo to reach the position
          if (buffer.indexOf("GET /?led1=0")>=0) {
            for (pos = 105; pos >= 0; pos -= 3) // goes from 180 degrees to 0 degrees
          // end new
        //Read in the buffer if there was send "GET /?message=..."
          if(buffer.indexOf("GET /?message=")>=0) {
            if(buffer.indexOf("switch on the light")>=0) {
            if(buffer.indexOf("switch on the fan")>=0) {
            if(buffer.indexOf("open the garage")>=0){
            if(buffer.indexOf("switch off the light")>=0) {
            if(buffer.indexOf("switch off the fan")>=0) {
            if(buffer.indexOf("close the garage")>=0){
        } //else closed
        else {
          currentLineIsBlank = false;
    delay(1);
    client.stop();
Please read the sticky post at the top of the topic: How to use this forum.
You failed to post a wiring diagram, links to the used hardware.
Forget the Android at the moment, use a standard browser on your PC. Once you got that working you might change to the Android device again.
"it does not work" is about the worst description of the problem you can provide. You might want to insert some serial debugging output into your sketch and post the output you get together with the changed code.
You cannot power a DC motor from a pin on the arduino. It can only supply about 30ma and your motor needs much more than that to run.
Simple rule of thumb: The Arduino is not a power supply it requires one! Start by getting the Arduino cookbook and reading it. Also on line there are many videos etc showing the Arduino and how to do what you want.
