Connection between phone and arduino via bluetooth
I've succeeded connecting my phone to the arduino via bluetooth and even send a messege from the phone to the arduino but I couldn't send a messege from the arduino to the phone.
#include <SoftwareSerial.h>
SoftwareSerial mySerial(2,3);
char c = ' ';
int buf[64];
int len = 0;
void setup (){
Serial.begin (9600);
Serial.println("Arduino is ready");
mySerial.begin(9600);
Serial.println("Bluetooth is ready");
void loop (){
if(Serial.available()){
len=Serial.available();
for(int i = 0; i<len;i++){
buf = Serial.read();
_ mySerial.write(buf*);_
_ Serial.write(buf);
if(mySerial.available()){
len=mySerial.available();
for(int i=0; i<len; i++){
buf = mySerial.read();
Serial.write(buf);
// for(int i=0;i<buf.length;i++)
// Serial.println(buf);
this was my program._
omridoren:
This should need no more than
Serial.println("hello");
and the hard stuff is in the opposite direction. I suspect your code is irrelevant, and it is more likely to be simply a matter of sloppy wiring. If you think the wiring is kosher, you might still test it by sending an AT command and wait for a non-response. If you actually get a response, it rather suggests that all your problems are at the Android end but, since you are actually able to send therefrom, I don't dare guess what it could be.
This is my wiring. Did I do something wrong there?
No, it's not your wiring, it is a picture of your intended wiring, drawn by Martyn Currey. Good guidance is no proof of proper execution.
omridoren:
As you can receive a message it seems the communication between Arduino and HC05 is fine. Are you sure your phone is actually receiving the response, and processing it as you intend?
Not really - you failed to add code tags (as described in the sticky) so it got treated as text and bbcode and mangled.
wvmarle:
How do I check it?
That's a very good question, and with you knowing exactly what you have installed on your phone you are the only one that can possibly answer that.
wvmarle:
I've downloaded the app called "Bluetooth Terminal HC-05"
You should not need an app that purports to be HC-05 specific, and I wouldn't trust it. Plain ordinary Bluetooth terminal should do.
I don't think I can build the code right. May anyone help me build a new one?
You might find the following background notes useful.
http://homepages.ihug.com.au/~npyner/Arduino/GUIDE_2BT.pdf
http://homepages.ihug.com.au/~npyner/Arduino/BT_2_WAY.ino
