Can some share me the circuit diagram for Connecting The 4X4 keypad and 16X2 Lcd Interfacing With Arduino Board. Is there any external Driver circuit Needed for Interfacing.
How many Being acquired. i checked link but could not able to find proper connection
It should work with the sketch you are using. Just make sure you use the same pin numbers as shown in the sketch. Or change the following lines to match the Arduino pin numbers you want to use.
http://arduino.cc/en/Tutorial/LiquidCrystal I have made connection as per circuit diagram , The LCD is not even blinking Here, Is above connetion is correct or extra driver to be added . any procedure to check LCD working fine or not.
