Connection problem with arduino nano and adafruit module RFM9x LoRa
Hi, I am Florian from Germany. I would like to read a temperature sensor in 1km distance by radio for example. I chose Adafruit’s 868Mhz Lora module for the radio connection. I got two 868 Mhz RFM95W LoRa Radio Breakouts from mouser.de Mouser No: 485-3072. I soldered the SMA connectors and post connectors and do the wiring with an original Arduino Nano 5V. The antenna is an 868MHz Whip Antenna, Right Angle, SMA Male Connector from modtronix.com
The power supply is via the USB socket of the arduino nano. Later it will be externally powered 5V. The connections are already exist.
I followed this instruction.
adafruit.com
So I download the libary ReadioHead for the Arduino IDE 1.8.5. In the sketch I wrote the Number for the Arduino Nano pin selection and the frequency. When I load the example sketch, I get this message in the serial monitor.
Console:
Feather RFM69 TX Test!
RFM69 radio init failed
My Sketch: Radio69_RawDemo_TX mod
// rf69 demo tx rx.pde
// -*- mode: C++ -*-
// Example sketch showing how to create a simple messaging client
// with the RH_RF69 class. RH_RF69 class does not provide for addressing or
// reliability, so you should only use RH_RF69  if you do not need the higher
// level messaging abilities.
// It is designed to work with the other example rf69_server.
// Demonstrates the use of AES encryption, setting the frequency and modem
// configuration
#include <SPI.h>
#include <RH_RF69.h>
/************ Radio Setup ***************/
// Change to 434.0 or other frequency, must match RX's freq!
#define RF69_FREQ 868.0
#if defined (__AVR_ATmega32U4__) // Feather 32u4 w/Radio
  #define RFM69_CS      8
  #define RFM69_INT     7
  #define RFM69_RST     4
  #define LED           13
#endif
#if defined(ADAFRUIT_FEATHER_M0) // Feather M0 w/Radio
  #define RFM69_CS      8
  #define RFM69_INT     3
  #define RFM69_RST     4
  #define LED           13
#endif
//#if defined (__AVR_ATmega328P__)  // Feather 328P w/wing
  #define RFM69_INT     3
  #define RFM69_CS      10
  #define RFM69_RST     2
  #define LED           13
//#endif
#if defined(ESP8266)    // ESP8266 feather w/wing
  #define RFM69_CS      2    // "E"
  #define RFM69_IRQ     15   // "B"
  #define RFM69_RST     16   // "D"
  #define LED           0
#endif
#if defined(ESP32)    // ESP32 feather w/wing
  #define RFM69_RST     13   // same as LED
  #define RFM69_CS      33   // "B"
  #define RFM69_INT     27   // "A"
  #define LED           13
#endif
/* Teensy 3.x w/wing
#define RFM69_RST     9   // "A"
#define RFM69_CS      10   // "B"
#define RFM69_IRQ     4    // "C"
#define RFM69_IRQN    digitalPinToInterrupt(RFM69_IRQ )
/* WICED Feather w/wing
#define RFM69_RST     PA4     // "A"
#define RFM69_CS      PB4     // "B"
#define RFM69_IRQ     PA15    // "C"
#define RFM69_IRQN    RFM69_IRQ
// Singleton instance of the radio driver
RH_RF69 rf69(RFM69_CS, RFM69_INT);//RFM69_INT
int16_t packetnum = 0;  // packet counter, we increment per xmission
  //while (!Serial) { delay(1); } // wait until serial console is open, remove if not tethered to computer
  pinMode(LED, OUTPUT);
  pinMode(RFM69_RST, OUTPUT);
  digitalWrite(RFM69_RST, LOW);// LOW
  Serial.println("Feather RFM69 TX Test!");
  // manual reset
  digitalWrite(RFM69_RST, HIGH);//HIGH
  Serial.println("RFM69_RST HIGH");
  delay(100); //10
  Serial.println("RFM69_RST LOW");
  delay(100);
  if (!rf69.init()) {
    Serial.println("RFM69 radio init failed");
    while (1);
    Serial.println("nach while");
  Serial.println("RFM69 radio init OK!");
  // Defaults after init are 434.0MHz, modulation GFSK_Rb250Fd250, +13dbM (for low power module)
  // No encryption
  if (!rf69.setFrequency(RF69_FREQ)) {
    Serial.println("setFrequency failed");
  // If you are using a high power RF69 eg RFM69HW, you *must* set a Tx power with the
  // ishighpowermodule flag set like this:
  rf69.setTxPower(20, true);  // range from 14-20 for power, 2nd arg must be true for 69HCW
  // The encryption key has to be the same as the one in the server
  uint8_t key[] = { 0x01, 0x02, 0x03, 0x04, 0x05, 0x06, 0x07, 0x08,
                    0x01, 0x02, 0x03, 0x04, 0x05, 0x06, 0x07, 0x08};
  rf69.setEncryptionKey(key);
  Serial.print("RFM69 radio @");  Serial.print((int)RF69_FREQ);  Serial.println(" MHz");
  delay(1000);  // Wait 1 second between transmits, could also 'sleep' here!
  char radiopacket[20] = "Hello World #";
  itoa(packetnum++, radiopacket+13, 10);
  Serial.print("Sending "); Serial.println(radiopacket);
  // Send a message!
  rf69.send((uint8_t *)radiopacket, strlen(radiopacket));
  rf69.waitPacketSent();
  // Now wait for a reply
  uint8_t buf[RH_RF69_MAX_MESSAGE_LEN];
  uint8_t len = sizeof(buf);
  if (rf69.waitAvailableTimeout(500))  {
    // Should be a reply message for us now
    if (rf69.recv(buf, &len)) {
      Serial.print("Got a reply: ");
      Serial.println((char*)buf);
      Blink(LED, 50, 3); //blink LED 3 times, 50ms between blinks
      Serial.println("Receive failed");
    Serial.println("No reply, is another RFM69 listening?");
void Blink(byte PIN, byte DELAY_MS, byte loops) {
  for (byte i=0; i<loops; i++)  {
    digitalWrite(PIN,HIGH);
    delay(DELAY_MS);
    digitalWrite(PIN,LOW);
    delay(DELAY_MS);
I have checked the correct pin assignment several times. See pictures attached.
With another arduino nano, I have already tried out. I already changed CS from pin 4 to pin 10 and it was the same error message. Finally, also tried the second LoRa module, no change. I’ve already searched several forums for a solution and found nothing.
Could you maybe help me with the LoRa modules to connect with the nano and in the next step to connect with each other?
Thanks
Florian
Why are you using the library and example for the RFM69 for a RFM95 ?
Might be an idea to try the library and examples for the RFM95 perhaps ?
Thanks, I overlooked that.
So I tried the rf95 client with the nano. Now it works.
Console output:
Sending to rf95_server
No reply, is rf95_server running?
Now I have connected the second lora module with an arduino pro mini 5V. The power supply is via the 5V USB-TTL adapter. The rf95 server sketch does not work there. The serial console is blank there is no feedback.
The pro mini has the pin assignment:
SCK - Pin13
MISO- Pin12
MOSI- Pin11
CS - Pin 4 (on the Nano Pin 10)
RST - Pin 2
G0 - Pin 3
client/Nano:
// rf95_client.pde
// ArduinoNano
// Example sketch showing how to create a simple messageing client
// with the RH_RF95 class. RH_RF95 class does not provide for addressing or
// reliability, so you should only use RH_RF95 if you do not need the higher
// It is designed to work with the other example rf95_server
// Tested with Anarduino MiniWirelessLoRa, Rocket Scream Mini Ultra Pro with
// the RFM95W, Adafruit Feather M0 with RFM95
#include <SPI.h>
#include <RH_RF95.h>
#define RFM95_CS 10
#define RFM95_RST 2
#define RFM95_INT 3
#define RF95_FREQ 868.0
RH_RF95 rf95(RFM95_CS, RFM95_INT);
  // Rocket Scream Mini Ultra Pro with the RFM95W only:
  // Ensure serial flash is not interfering with radio communication on SPI bus
  //  pinMode(4, OUTPUT);
  //  digitalWrite(4, HIGH);
  rf95.setTxPower(17, true);
  while (!Serial) ; // Wait for serial port to be available
  if (!rf95.init())
    Serial.println("init failed");
  // Defaults after init are 434.0MHz, 13dBm, Bw = 125 kHz, Cr = 4/5, Sf = 128chips/symbol, CRC on
  // The default transmitter power is 13dBm, using PA_BOOST.
  // If you are using RFM95/96/97/98 modules which uses the PA_BOOST transmitter pin, then
  // you can set transmitter powers from 5 to 23 dBm:
  //  driver.setTxPower(23, false);
  // If you are using Modtronix inAir4 or inAir9,or any other module which uses the
  // transmitter RFO pins and not the PA_BOOST pins
  // then you can configure the power transmitter power for -1 to 14 dBm and with useRFO true.
  // Failure to do that will result in extremely low transmit powers.
  //  driver.setTxPower(14, true);
  Serial.println("Sending to rf95_server");
  // Send a message to rf95_server
  uint8_t data[] = "Hello World!";
  rf95.send(data, sizeof(data));
  rf95.waitPacketSent();
  uint8_t buf[RH_RF95_MAX_MESSAGE_LEN];
  if (rf95.waitAvailableTimeout(3000))
    if (rf95.recv(buf, &len))
      Serial.print("got reply: ");
//      Serial.print("RSSI: ");
//      Serial.println(rf95.lastRssi(), DEC);
      Serial.println("recv failed");
    Serial.println("No reply, is rf95_server running?");
  delay(400);
server/Pro Mini
// rf95_server.pde
// Arduino Pro Mini
// Example sketch showing how to create a simple messageing server
// It is designed to work with the other example rf95_client
#include <SPI.h>
#define RFM95_CS  4
#define RFM95_RST 2
#define RFM95_INT 3
int led = 9;
  pinMode(led, OUTPUT);
  if (!rf95.init())
  if (rf95.available())
    // Should be a message for us now
      digitalWrite(led, HIGH);
//      RH_RF95::printBuffer("request: ", buf, len);
      Serial.print("got request: ");
      // Send a reply
      uint8_t data[] = "And hello back to you";
      Serial.println("Sent a reply");
       digitalWrite(led, LOW);
Flo9102:
Glad you got it working.
