how to make communication serial arduino uno to wireless module KYL-200U ???
wiring and programing code ???
The body of your post seems to have little to do with the question.
Anyway lookup the vertuial wire libary for communications.
I used virtual wire but is not function and can't connect
So tell us how you have wired it up. A schematic of this would be good, much better than words, also the code you are trying to use should be posted in the correct code tags.
This is the wiring wireless module,, I only use RxD and TxD TTL to arduino uno
This is Rx code
#include <VirtualWire.h> // you must download and install the VirtualWire.h to your hardware/libraries folder
#undef int
#undef abs
#undef double
#undef float
#undef round
// Initialise the IO and ISR
vw_set_ptt_inverted(true); // Required for RX Link Module
vw_setup(2000); // Bits per sec
vw_set_rx_pin(23); // We will be receiving on pin 23 (Mega) ie the RX pin from the module connects to this pin.
vw_rx_start(); // Start the receiver
uint8_t buf[VW_MAX_MESSAGE_LEN];
uint8_t buflen = VW_MAX_MESSAGE_LEN;
if (vw_get_message(buf, &buflen)) // check to see if anything has been received
int i;
// Message with a good checksum received.
for (i = 0; i < buflen; i++)
Serial.print(buf[i]); // the received data is stored in buffer
Serial.println("");
and this is TxD code
#undef int
#undef abs
#undef double
#undef float
#undef round
vw_set_ptt_inverted(true); // Required for RF Link module
vw_set_tx_pin(3); // pin 3 is used as the transmit data out into the TX Link module, change this to suit your needs.
const char *msg = "LMR-II Rocks"; // this is your message to send
vw_send((uint8_t *)msg, strlen(msg));
vw_wait_tx(); // Wait for message to finish
delay(200);
Have you connected the grounds together?
yes, of course
with ground and VCC 5V of both,,
but still no response(connected)
i want to ask about that topic,
i use KYL-200l but i dont know how to use it,
can you explained me how to wairing and ardunio code about KYL-200l ??
Thank you
