HI,
I am working on piezo transducers to display heat mapping on Processing. From serial plotter, we already figured that the sensors work when apply pressure on it. But, when we try to display output in form of heat mapping in Processing, it doesn't work. So, i hope u can help with the coding as below in attachments. For your information, we use for units of 16 bits ADC ADS1115 to test for 16 piezo sensors.
thank you and hope you can help me.
below are the coding for processing :
import controlP5.;
ControlP5 cp5;
Slider s1;
//Textarea myTextarea1;
//Textarea myTextarea2;
int myColor = color(0,0,0);
int sliderTicks2 = 100;
Slider abc;
import processing.serial.;
Serial myPort; // The serial port
float x,y,w,q;
Blob[] blobs = new Blob[16];
PShape bot; // 000,001,002,003,004,005,006, 007, 008,009,010,011,012,013,014,015
int[][] timeLine = { {000,000,000,000,000,000,000, 000, 000,000,000,000,000,000,000,000},
size(640, 360);
cp5 = new ControlP5(this);
/*myTextarea2 = cp5.addTextarea("txt2")
.setPosition(150,10)
.setSize(250,30)
.setFont(createFont("arial",22))
.setLineHeight(14)
.setColor(color(255))
.setColorBackground(color(0,0))
.setColorForeground(color(255,255));
myTextarea2.setText("Patient :- Mr.chiprobot"
s1 = cp5.addSlider("Milliseconds")
.setColorLabel(0)
.setPosition(20,330)
.setWidth(500)
.setHeight(25)
.setRange(0,14) // values can range from big to small as well
.setValue(.2)
.setColorTickMark(0)
.setNumberOfTickMarks(60)
.setSliderMode(Slider.FLEXIBLE)
cp5.addButton("buttonScan")
.setPosition(20,275)
.setImages(loadImage("button_scan_green.png"), loadImage("button_scan_blue.png"),loadImage("button_scan_orange.png"))
.updateSize();
cp5.addButton("buttonLive")
.setPosition(130,275)
.setImages(loadImage("button_live_green.png"), loadImage("button_live_red.png"),loadImage("button_scan_green.png"))
.updateSize();
cp5.addButton("buttonReset")
.setPosition(500,275)
.setImages(loadImage("button_reset_green.png"), loadImage("button_reset_blue.png"),loadImage("button_reset_orange.png"))
.updateSize();
cp5.addButton("alligator_50")
.setPosition(10,10)
.setImages(loadImage("alligator_50.png"),loadImage("chiprobotakagareth.png"),loadImage("chiprobotakagareth.png"))
.updateSize();
cp5.addButton("Hackadayio")
.setPosition(470,2)
.setImages(loadImage("hackadaymetal25.png"),loadImage("hackadaymetal25.png"),loadImage("hackadaymetal25.png"))
.updateSize();
printArray(Serial.list()); // print list of active serial ports
myPort = new Serial(this, Serial.list()[1], 38400); // adjust serial port number to suit
colorMode(HSB);
blobs[0] = new Blob(555,133);
blobs[1] = new Blob(490,127);
blobs[2] = new Blob(430,115);
blobs[3] = new Blob(357,140);
blobs[4] = new Blob(255,160);
blobs[5] = new Blob(154,145);
blobs[6] = new Blob(85,138);
blobs[7] = new Blob(425,175);
blobs[8] = new Blob(552,193);
blobs[9] = new Blob(488,213);
blobs[10] = new Blob(424,238);
blobs[11] = new Blob(364,226);
blobs[12] = new Blob(294,222);
blobs[13] = new Blob(214,214);
blobs[14] = new Blob(141,209);
blobs[15] = new Blob(72,203);
bot = loadShape("soles.svg");
void draw() {
for (int w = 0; w <= 15; w++) {
for (int x = 0; x <= 15; x++) {
if (myPort.available() > 0)
int lowByte = myPort.read();
delay(10);
int highByte = myPort.read();
int value = highByte * 256 + lowByte;
timeLine[w][x]=value/256;
println(w,x,value);
background(51);
loadPixels();
for (int x = 0; x < width; x++) {
for (int y = 0; y < height; y++) {
int index = x + y * width;
float sum = 0;
for (Blob b : blobs) {
float d = dist(x, y, b.pos.x, b.pos.y);
w=timeLine[int( s1.getValue())][int(q)];
sum += 10 * w / d;
q=q+1;
// println(b.r);
// delay(1);
q=0;
pixels[index] = color(sum, 255, 255);
updatePixels();
shape(bot, -90, -50, 800, 450);
//fill(sliderTicks2);
//rect(0,350,width,50);
//float r= s1.getValue();
//println(b.r);
public void controlEvent(ControlEvent theEvent) {
println(theEvent.getController().getName());
// function buttonReset will receive changes from
// controller with name buttonReset
public void buttonReset(int theValue) {
println("a button event from buttonReset: "+theValue);
myColor = color(128);
// function buttonLive will receive changes from
// controller with name buttonScan
public void buttonLive(int theValue) {
println("a button event from buttonLive: "+theValue);
// function buttonScan will receive changes from
// controller with name buttonA
public void buttonScan(int theValue) {
println("a button event from buttonScan: "+theValue);
// function alligator will receive changes from
// controller with name alligaitor
public void alligator (int theValue) {
println("a button event from alligator: "+theValue);
// function hackadayio will receive changes from
// controller with name hackadayio
public void hackadayio(int theValue) {
Here are the link that we refer to : https://hackaday.io/project/11154/instructions
