So I'd like to have a connector to go through the case of my project such that I can disconnect auxiliary components when moving or whatever.
I need something in the 10+ pin range that can handle ~1.5A+ per pin.
I was looking at Molex's 'Microclasp' line, however, being this is my first time using such connectors, I am a bit confused. I understand that there is a female plastic piece that is then filled with crimped pins and connected to whatever. Then there is a male plastic piece that takes male crimp pins, and then connects to the female piece. However, looking at mouser for 10 pin connectors only female housings show up. If you sort all of the 'Microclasp' results by male gender, only the crimp pins and 2 and 3 pin housings show up.
Does this mean that mouser does not offer the male half of the connector for anything that is 4+ pins? Or am I misunderstanding the classification and/or terminology of the parts? For instance, is there a difference between a "receptacles", "sockets", and "headers"? Are all of those female housings, or are the "headers" the male housings? Which doesn't really matter in the case of the 10pin components offered by mouser, as both are listed as "receptacles" where one is a single row and the other two rows.
