Connectors
I am looking for some good connectors for Arduino projects. They should be easy to permanent mount in a box with external female connectors to hookup things like, pir, servo etc..
/Johan
If you want to go crazy overkill on connectors, try D38999 connectors.
Or use db9 and db15 connectors and arrange them so that selected pins perform specific functions - for example all pin 1 are +5volts and all pin 2 are 0volts, odd pins are inputs, even pins are outputs etc
Or binding posts if you want to plug in banana jacks, or unterminated wires. Examples:
Perhaps panel mount connectors for power source too
Thanks guys,
The D38999 looks nice. But a bit pricy to put it mildly :slight_smile:
I like the dsub and banana jack options. I will put in an order ASAP. Thanks again guys!
/Johan
