Connectors
New to Arduino, trying to build a project at home with the Arduino Uno WiFi REV2 and am looking for connectors to wire terminal strips inside my control cabinet directly to the arduino board. Something like 1,2,3,4 or 5 pin Molex connectors. I've tried looking online for the connectors, and on the Arduino site but have had no real luck. Do they exist? If so where can I obtain them? I did run across the 10 jumper wires in the Arduino store. Will I just have to use these and cut one end off to land onto my terminals?
Thanks in advance
You can buy screw shields for Arduino - would that do it ?
hammy:
Yes, that would work. I found this on Amazon. Do you know if it's compatible? The description on the page states it is for uno rev1-3, but I wanted to make sure it would since I purchased the WiFi board. -
https://www.amazon.com/dp/B014SGTP20/ref=cm_sw_em_r_mt_dp_U_N2qHEbH48KZDZ
Try a google search for "Molex connectors."
Before I tell you no problem the screw shields will work take a long look at your link to the screw shields and that same long look at your board. My take is yes the screw shields will work fine with your board but I would look at the screw shields and your board pin by pin to make sure.
Ron
Ok, I've purchased the shield so I hope all goes well. Seems to look like it should work just fine. Thank you for the help
