i test ConnectWithWPA but is not running.
Yellow LED is slow blink after Upload and no Output SerialConsole, when USB pluged again
there is Yellow LED off.
How do you know it's not running?
Maybe it's running - but failing.
It would help if you showed the code
Show how you have wired it, an annotated schematic would be a bit help.
its the example in the new UNO R4 Section.
After minutes its began to try to log in the Wifi, but its not connect.
my UNO Wifi 2 runs perfect.
@reikodd was the upload successful? did you add the credentials in the arduino_secrets.h tab? is there anything connected to the board?
with the ESP Firmware 0.2.0 running now.
But flashing only with Jumper by macos. Windows Flash not running. :-/
Who could have guessed that a board would be sold that was not finished on the software side :-/ And then again the user who has been making Arduino for 10 years is too stupid
