Connessiona a pagina con autenticazione con Arduino + Ethernet
Ciao a tutti,
devo fare in modo che arduino UNO si colleghi via ethernet a una pagina web con autenticazione.
Ho provato a usare la libreria EthernetClient con base authentication, ma ho ricevuto l'errore:
connecting...
http://192.168.1.181/SystemLog.htm
QWRtaW46MDEyMzQ1
connected
HTTP/1.1 401 Unauthorized
WWW-Authenticate: Basic realm="Protected"
Connection: close
401 Unauthorized: Password required
disconnecting.
Qualcuno mi può dare qualche consiglio? non riesco a capire come risolvere. Riporto il mio sketch.
grazie
#include <SPI.h>
#include <Ethernet.h>
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
IPAddress server(192,168,1,181);
IPAddress ip(192,168,1,255);
EthernetClient client;
   while (!Serial) {
    ; // wait for serial port to connect. Needed for Leonardo only
  // start the Ethernet connection:
  if (Ethernet.begin(mac) == 0) {
    Serial.println("Failed to configure Ethernet using DHCP");
    // no point in carrying on, so do nothing forevermore:
    // try to congifure using IP address instead of DHCP:
    Ethernet.begin(mac, ip);
  // give the Ethernet shield a second to initialize:
  Serial.println("connecting...");
  Serial.println("http://192.168.1.181/SystemLog.htm");
  Serial.println("QWRtaW46MDEyMzQ1");
  // if you get a connection, report back via serial:
  if (client.connect(server, 80)) {
    Serial.println("connected");
    // Make a HTTP request:
    //client.println("GET /search?q=arduino HTTP/1.1");
    client.println("POST /SystemLog.htm");
    client.println("Host: 192.168.1.181");
    client.println("Authorization: Basic QWRtaW46MDEyMzQ1");
    client.println("Connection: close");
    client.println();
  else {
    // kf you didn't get a connection to the server:
    Serial.println("connection failed");
  // if there are incoming bytes available
  // from the server, read them and print them:
  if (client.available()) {
    char c = client.read();
    Serial.print(c);
  // if the server's disconnected, stop the client:
  if (!client.connected()) {
    Serial.println("disconnecting.");
    client.stop();
    // do nothing forevermore:
    while(true);
>joyce973: in conformità al REGOLAMENTO della sezione Italiana del Forum, punto 13, il cross-posting è proibito (anche tra lingue diverse) e tu hai già posto la stessa domanda QUI.
Poi, NON avendolo tu ancora fatto, ti chiedo cortesemente di presentarti IN QUESTO THREAD (spiegando bene quali conoscenze hai di elettronica e di programmazione ... possibilmente evitando di scrivere solo una riga di saluto :wink:) e di leggere con MOLTA attenzione il REGOLAMENTO.
Infine, nel rispetto del regolamento, questo tuo thread viene chiuso e ti prego di continuare dove avevi cominciato. Grazie.
Guglielmo
