Il progetto che sto svolgendo è composto da un ESP8266, da un TMP256 (Rilevatore per la temperatura) e da un Web Service.
Quello che devo fare è: prendere il dato che mi restituisce il sensore e inviarlo tramite metodo GET ad un API.
#include <ESP8266WiFi.h>
#define TMPPin A0
String temperatureString = "";
const char* ssid = "xxxxxxxxxxxx";
const char* password = "xxxxxxxxxxxxx";
const char* host = "192.168.0.106";
const uint16_t port = 443;
Serial.print("Connecting to ");
Serial.println(ssid);
WiFi.mode(WIFI_STA);
WiFi.begin(ssid, password);
Serial.print(".");
Serial.println("");
Serial.println("WiFi connected");
Serial.println("IP address: ");
Serial.print("connecting to ");
Serial.print(host);
Serial.print(':');
Serial.println(port);
WiFiClientSecure c;
if (!c.connect(host, port)) {
Serial.println("connection failed");
delay(5000);
return;
Serial.println("sending data to server");
if (c.connected()) {
//ONLY FOR TEST
//float temp = 0;
int id_d = 16;
int tmpValue = analogRead(A0);
float voltage = tmpValue * 3.3;
voltage /= 1024.0;
float temperatureC = (voltage - 0.5) * 100 ;
float temperatureF = (temperatureC * 9.0 / 5.0) + 32.0;
temperatureString = " " + String(temperatureC) + " C " +
String(temperatureF) + " F ";
Serial.println(temperatureString);
//TEST
String queryString = "temp=" + String(temperatureC) + "&id_d=" + String(id_d);
String url = "GET /ProjectESP8266/insert_data.php?" + queryString + " HTTP/1.1";
c.println(url);
c.println("Host: as_proj_ESP8266");
c.println("Access-Control-Allow-Origin: *");
c.println("Connection: close");
c.println();
unsigned long timeout = millis();
while (c.available() == 0) {
if (millis() - timeout > 5000) {
Serial.println(">>> Client Timeout !");
c.stop();
delay(60000);
return;
Serial.println("receiving from remote server");
while (c.available()) {
char ch = static_cast<char>(c.read());
Serial.print(ch);
Serial.println("closing connection");
c.stop();
delay(300000);
Nel monitor seriale però mi dice che non la connessione con l'IP del mio PC è fallita (in poche parole non si collega nemmeno). Ho provato a mettere pure come indirizzo IP 127.0.0.1
P.S: Sto lavorando in locale, sia il database che l'API sono in localhost
