connexion between 2 xbees
Hi :slight_smile:
My project consists in linking two cards Arduino via xbee :one card Arduino will send data (L and H) and
the other card will flash the LED( it will turn on the LED when it receives H and turn off the led when it receives L)
Here is the code
/* Sender
Serial.println("H"); //turn on the LED
Serial.println("L");//turn off the LED
/*Receiver
char msg = ' '; //contains the message from arduino sender
const int led = 13; //led at pin 13
Serial.begin(9600);//Remember that the baud must be the same on both arduinos
pinMode(led,OUTPUT);
while(Serial.available() > 0) {
msg=Serial.read();
if(msg=='H') {
digitalWrite(led,HIGH);
if(msg=='L') {
digitalWrite(led,LOW);
I realized the isis scheme but it didn't work
I tried to connect the two cards by a wire connection to ensure safe operation and it worked
Finally, I noticed that the Dout pin of xbee Rx connected to the Arduino board is not functional (the color is gray) but I have not experienced the problem
here is the code
I realized the isis scheme but it did not work
I tried to connect the two cards by a wire connection and it worked
Finally, I noticed that the Dout pin of xbee Rx connected to the Arduino board is not functional (the color is gray) but I didn't find d the problem
this image shows that when I connected the two arduino cards without xbee it has worked
