cons13
Que tal, necesito ayuda para hacer la programación de el siguiente problema: tengo un contador de metros y quiero que mande un pulso a un variador de velocidades a ciertos metros de cadena contados (20mts) para que aumente o disminuya la velocidad, como podría hacer ese ciclo en este lenguaje de programación?
Saludos.
Perhaps you've noticed that everyone else posting in this part of the forum is posting in English, and getting answers. You didn't and you aren't. Have you wondered why you weren't?
Requesting that this be moved to the Spanish-language forum. The Google translation doesn't make much sense.
How about, I need help to make programming the following problem: I have a meter counter and I want to send a pulse to a certain speed variator chain counted meters (20mts) to increase or decrease the speed as you could do that cycle in this programming language?
Greetings.
johnwasser: How about, I need help to make programming the following problem: I have a meter counter and I want to send a pulse to a certain speed variator chain counted meters (20mts) to increase or decrease the speed as you could do that cycle in this programming language?
Is 20 mts considered "fast" for a certain speed variator chain?
Por favor cambia el titulo del post por algo mas explicativo sobre la consulta que quieres hacer y no tu nick.para que te ayuden deberias dar mas datos ,sobre todo ,modelos de los sensores y variador con los que vas a trabajar o mejor su datashet y explicar mas detalladamente lo que quieres hacer.
Ademas de hacer lo que te dice josé busca variador en este foro. Hay algo hecho en modbus con un Danfoss FC51
