[Conseil] Aide programme GSM et GPS
Bonjour, je doit pour mon projet pouvoir envoyer a un numero la postion gps de l'arduino quand celui ci le demande par gps. Mais j'ai un probleme dans mon programme , d'apres des recherche c'est a cause des librairies GSM et GPS mais je n'ai pas de solution
Voila le programme
#include <SoftwareSerial.h>
#include <TinyGPS.h>
#include <Wire.h>
#include <GSM.h>
int val = 0; // variable to store the read value
const float c = 11;
const float d = 22;
define PINNUMBER "0000" //definir le code PIN
// initialiser l'instance bibliothèque
GSM gsmAccess;
GSM_SMS sms;
TinyGPS gps;
SoftwareSerial ss(7, 6);
char remoteNumber[20];
ss.begin(4800);
Serial.print("Simple TinyGPS library v. "); Serial.println(TinyGPS::library_version());
Serial.println("by Mikal Hart");
Serial.println("SMS Messages Receiver");
//Etat de la connection
boolean notConnected = true;
// Démarrer le shield GSM
while(notConnected)
if(gsmAccess.begin(PINNUMBER)==GSM_READY)
notConnected = false;// Si la carte sim ou le shield gsm n'est pas connecter
Serial.println("Non connecter");// Afficher "non connecter"
Serial.println("GSM initialiser");
Serial.println("En attente de message");
GPS();
void GPS(){
char c;
bool newData = false;
unsigned long chars;
unsigned short sentences, failed;
// For one second we parse GPS data and report some key values
for (unsigned long start = millis(); millis() - start < 1000;)
while (ss.available())
char c = ss.read();
// Serial.write(c); // uncomment this line if you want to see the GPS data flowing
if (gps.encode(c)) // Did a new valid sentence come in?
newData = true;
if (newData)
// If there are any SMSs available()
if (sms.available())
Serial.println("Message reçus du:"); //Imprimer sur le moniteur "Message reçus de:"
// Get remote number
sms.remoteNumber(remoteNumber, 20);
Serial.println(remoteNumber);
while(c=sms.read())
float flat, flon;
unsigned long age;
gps.f_get_position(&flat, &flon, &age);
Serial.print("LAT=");
Serial.print(flat == TinyGPS::GPS_INVALID_F_ANGLE ? 0.0 : flat, 6);
Serial.print(" LON=");
Serial.print(flon == TinyGPS::GPS_INVALID_F_ANGLE ? 0.0 : flon, 6);
Serial.print(" SAT=");
Serial.print(gps.satellites() == TinyGPS::GPS_INVALID_SATELLITES ? 0 : gps.satellites());
Serial.print(" PREC=");
Serial.print(gps.hdop() == TinyGPS::GPS_INVALID_HDOP ? 0 : gps.hdop());
gps.stats(&chars, &sentences, &failed);
Serial.print(" CHARS=");
Serial.print(chars);
Serial.print(" SENTENCES=");
Serial.print(sentences);
Serial.print(" CSUM ERR=");
Serial.println(failed);
if (chars == 0)
Serial.println("** No characters received from GPS: check wiring **");
sms.beginSMS("0000000000");
sms.print(TinyGPS::GPS_INVALID_F_ANGLE ? 0.0 : 6);
sms.endSMS();
sms.flush();
int readSerial(char result[])
int i = 0;
while (1)
while (Serial.available() > 0)
char inChar = Serial.read();
if (inChar == '\n')
result[i] = '\0';
Serial.flush();
return 0;
if (inChar != '\r')
result[i] = inChar;
i++;
Et en message d'erreur
GSM\GSM3SoftSerial.cpp.o: In function `__vector_3':
C:\Program Files (x86)\Arduino\libraries\GSM\src/GSM3SoftSerial.cpp:499: multiple definition of `__vector_3'
SoftwareSerial\SoftwareSerial.cpp.o:C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SoftwareSerial/SoftwareSerial.cpp:227: first defined here
GSM\GSM3SoftSerial.cpp.o: In function `GSM3SoftSerial::spaceAvailable()':
C:\Program Files (x86)\Arduino\libraries\GSM\src/GSM3SoftSerial.cpp:487: multiple definition of `__vector_4'
SoftwareSerial\SoftwareSerial.cpp.o:C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SoftwareSerial/SoftwareSerial.cpp:392: first defined here
C:\Program Files (x86)\Arduino\libraries\GSM\src/GSM3SoftSerial.cpp:487: multiple definition of `__vector_5'
collect2.exe: error: ld returned 1 exit status
J'ai vraiment besoin d'aide alors si vous avez des idée je suis preneur
GSM.h implémente son propre software Serial qui reprend en grande partie SoftwareSerial.h ... Donc il y a des doublons que le compilo n'aime évidemment.
Y'a pas 36 solutions :
Ok merci , maintenant sa donne sa :
#include <AltSoftSerial.h>
#include <Wire.h>
#include <GSM.h>
const float c = 11;
#define PINNUMBER "0000" //definir le code PIN
 GSM gsmAccess;
 GSM_SMS sms;
 TinyGPS gps;
AltSoftSerial ss(9, 8);
  ss.begin(4800);
   while(notConnected)
   GPS();
  void GPS(){
    char c;
      char c = ss.read();
        newData = true;
  if (newData)
  while(c=sms.read())
     float flat, flon;
    unsigned long age;
  if (chars == 0)
       sms.beginSMS("000000000");
      sms.endSMS();
    sms.flush();
  int i = 0;
  while (1)
      if (inChar == '\n')
        result[i] = '\0';
        Serial.flush();
        return 0;
      if (inChar != '\r')
        result[i] = inChar;
        i++;
J'ai pu de probleme lors de la compilation mais dans le moniteur sa reste bloquer a SMS Messages Receiver T'aurais pas une idée du probleme ?
T'as essayé en inversant 9 et 8 ?
